XK8 / XKR 4.0L Air Filter Replacement
Old Oct 22, 2015 | 04:01 PM
Rocky15's Avatar
Default XK8 / XKR 4.0L Air Filter Replacement
Hi
Can anyone please tell me how to check the air filter on my XKR as I don't want to remove anything I don't need to.
I see there are about 3 clips on one side of the box and 1 at the back. Do I just unclip these and lift the box off or is there more to it?
Regards
Ade
Old Oct 22, 2015 | 05:09 PM
Stumpy's Avatar
As you do not include your year, here are the details for the early version
Old Oct 22, 2015 | 05:10 PM
Jag#4's Avatar
Yes it is that simple. Just watch out for the hose connected to the removable top cover.
BTW there is more than one on the back side, just to make it interesting.
Here is a shot of it opened up with the air filter out.
Attached Thumbnails XK8 / XKR 4.0L Air Filter Replacement-airbox.jpg
Old Oct 22, 2015 | 06:49 PM
DaveInVA's Avatar
You may also find the rubber isolater piece under the bottom cover that connects to the fender is broken and this is a good time to replace it.
Dave
Old Oct 23, 2015 | 04:24 AM
Rocky15's Avatar
Many thanks for the info.
Thought it's best to check before I venture into the unknown as last time I opened an air filter cover it just looked like a frying pan sat on top of my Ford Escort engine.
Ade
Old Oct 25, 2015 | 12:31 PM
chopr's Avatar
I found a good way to "cheat" if the engine is hot, etc! That rear tab can leave your hands burning! You can pry the "snorkel" that goes from the air box into the right front fender away from the airbox, and use a small mirror and flashlight to look at the air filter while it is still in place. There is a small tab on the top and on the bottom of the snorkel that holds it into the box. Just push down and pry out. These filters seem to last 25k miles in typical conditions.
Jon89
Dec 28, 2017 12:06 AM
mhamilton
Jul 29, 2016 12:22 PM
Stilling
XJ40 ( XJ81 )
Oct 30, 2015 02:20 AM
Jagman28
Oct 25, 2015 05:33 PM
philwarner
Oct 23, 2015 03:54 PM
