XKR 100, Same part at double the price?
Old Jul 18, 2018 | 06:54 AM
Sapphire Blue's Avatar
Default XKR 100, Same part at double the price?
I have a small drip of Power Steering Oil coming from the end of the Power Steering cooler (Near-side front, UK) on my 1999 XKR.
Our local independent Jag specialist tried and failed to remedy the drip. So I've been looking at ways to clean up the problem.
kgpumps gives a good option in his post, I've also checked out the cost of a replacement part at British Parts UK.
That's where I become confused, they look identical in the provided image, apart from the price and part number, what makes them so different between models?
Any chance anyone can enlighten me, or confirm I could use the XK8 version on my XKR.
Two options are listed, for XK8 & XKR owners:
POWER STEERING OIL COOLER
Power steering hose includes oil cooler
Jaguar XK8 1996 to 2001 to vin A11050
Part No. MJA8084AB
£120.00
Jaguar XKR 1996 to 2001 to vin A11050
Part No. MJB8084AA
£243.57
Thanks in advance.
Last edited by Sapphire Blue; Jul 18, 2018 at 08:07 AM. Reason: Correction to text
Old Jul 18, 2018 | 07:39 AM
Robert Grisar's Avatar
Suggest you consider other sources. eBay for example. Several listing include a grid that shows what part fits your vehicle. I have found this a tremendous source of valuable information.
Old Jul 18, 2018 | 07:54 AM
michaelh's Avatar
Jaguar Heritage appears to keep them at around the £120 mark:
https://www.jaguarclassicparts.com/u...voir-and-hoses
I'd expect OEM or OEM quality from Heritage.
Old Jul 18, 2018 | 07:57 AM
michaelh's Avatar
Sorry - just seen your sig. You have a 99XKR rather than an XKR100
At work & can't edit my post
Old Jul 18, 2018 | 07:58 AM
Thanks both for your speedy replies. However it's whether the XK8 part is compatible with my XKR that I'm after confirming.
The Vin numbers for both are identical.
Old Jul 18, 2018 | 08:08 AM
Thank's for correcting me on my heading, michaelh
Old Jul 18, 2018 | 08:17 AM
michaelh's Avatar
De nada. I should have read to the end of your post...
Old Jul 18, 2018 | 08:22 AM
fmertz's Avatar
You might have to come up with a strategy for this, depending on the amount of trouble you are willing to go through. Order both and return the one that does not fit, provided the vendor does not make this cost-prohibitive (restocking fees, etc.). Or order the cheaper part and do a test fit with the actual old part. Also, take a hard look at what is there on your own car already, and try and figure out why there would be 2 different parts. My suspicion is that somehow the XKR part has longer hoses to go around other XKR-specific parts, like the intercooler radiator, but this is just a pure guess. Another guess (based on the neighborhood) would be that there is somehow a difference based on the 2 different models of oil coolers.
Old Jul 18, 2018 | 09:33 AM
dibbit's Avatar
The SNG catalogue shows that both parts fits both XK8 and XKR:-
https://www.sngbarratt.com/uk/#!/Eng...2-07e60a4061a5
https://www.sngbarratt.com/uk/#!/Eng...f-0c648b94f60f
It might be worth confirming with them what the difference is.
Old Jul 19, 2018 | 03:30 AM
Thanks for spotting this for me,
dibbit.
Certainly worth pursuing for the price advantage.
Old Jul 19, 2018 | 03:33 AM
Thanks for your reply, fmertz.
Good suggestion of checking other XKR specific parts that could cause the required difference.
Old Dec 28, 2020 | 06:18 PM
ragtopXKR's Avatar
Did you ever determine if the XK8 PS cooler hose would fit your XKR? I have the same leak in my 2000 XKR (built in 1999)
Brent
crtfour
Dec 23, 2017 03:32 PM
Johnken
May 17, 2017 09:09 AM
JimC64
May 7, 2016 08:53 PM
NaplesTopLess
Sep 18, 2013 05:35 PM
