xkr 2001 argentina , chain tensioner
Old Dec 18, 2012 | 06:20 PM
tanngo's Avatar
Default xkr 2001 argentina , chain tensioner
I have only 19,000 miles, xkr 2001, Argentina, after 4 days starting chain blow, I fear the chain tensioners ... Replacement hours
secunadrios besides metal tensioners, need screws, valve cover gasket and something else?
Old Dec 19, 2012 | 06:31 AM
Dennis07's Avatar
Tanngo,
I do not mean to be critical, but I think people here may not understand what you are asking us.
Is this close? ... You think your secondary tensioners may have failed ... you want to know about the parts required to fix this, and also the number of hours of labor required.
Please try your questions again. En otras palabras, por favor.
Old Dec 19, 2012 | 06:39 AM
steveinfrance's Avatar
As Dennis says - we want to help and do understand the language problem so try your best!
The big question - has the timing chain broken ? If so this could mean serious engine damage.
Whatever you do DO NOT try to start or turn the engine over with the starter until we know a bit more.
Buena suerte !
Old Dec 19, 2012 | 08:12 AM
tanngo's Avatar
I speak Spanish, google translator. Thank you. noise on startup, xkr 19,000 miles, chain tensioners need changing.
Old Dec 19, 2012 | 09:01 AM
RJ237's Avatar
The tensioners, longer bolts, and gasket set are all you need for XK8, and I don't believe XKR is different. Do you need torque wrench settings?
If you use zip tie method it should take 6- 8 hrs. including cleanup.
Old Dec 19, 2012 | 09:20 AM
Problem is that we do not know if he has bent a valve.
(translates OK with Google)
tanngo's Avatar
gracias .... Do you need torque wrench settings? yes , yes ..
Old Dec 19, 2012 | 09:25 AM
tanngo's Avatar
noise only start, I will prevent. car goes well.
Old Dec 19, 2012 | 09:52 AM
OK, good news. DO NOT DRIVE until you have fixed the tensioners.
Risk of serious engine damage
Old Dec 19, 2012 | 10:46 AM
RJ237's Avatar
Torque settings. The first value is for old bolts, second for new, I think.
Ignition Coil 4-6 Nm
Cam Cover 9-11 Nm
Tensioner Bolts 10-14 Nm
Cam Caps 9-11 Nm
Do not forget to pull the pins from the tensioners after installing.
Disable Fuel Pumps and turn engine over until oil gauge shows pressure before restarting.
Old Dec 19, 2012 | 12:29 PM
tanngo's Avatar
Thumbs up
Originally Posted by rj237
torque settings. The first value is for old bolts, second for new, i think.
Ignition coil 4-6 nm
cam cover 9-11 nm
tensioner bolts 10-14 nm
cam caps 9-11 nm
do not forget to pull the pins from the tensioners after installing.
Disable fuel pumps and turn engine over until oil gauge shows pressure before restarting.
muchas gracias
picard
Oct 12, 2015 11:56 AM
Bowman
Sep 15, 2015 06:54 AM
Dicque
Sep 12, 2015 10:34 AM
davidladewig
Sep 11, 2015 06:48 PM
convincor
Sep 10, 2015 06:50 AM
