XKR gearbox 'slipping'
Old Jan 8, 2021 | 02:01 PM
dalo's Avatar
Default XKR gearbox 'slipping'
When I reversed my XKR (X100) into the garage this evening the car slowed down to a stop even though the engine didn't. Normally I can get in with the engine little more than idling.To get into the garage the car goes up a very small slope. I had to rev the engine to get it in. It was like clutch slip on a manual gearbox. I believe it has a Mercedes automatic gearbox. Can anyone suggest what might be happening? The car has done about 89,000 miles and has been serviced regularly.
Many thanks.
Old Jan 8, 2021 | 02:36 PM
baxtor's Avatar
Many thanks.
First task must be check the fluid level. Dipsticks and filler tube cap locks are readily available online although the filler tube cap can be reused without a lock
Use only Mercedes approved fluid.
Old Jan 8, 2021 | 03:21 PM
dalo's Avatar
Thank you. I'll try that.
Old Jan 9, 2021 | 01:32 PM
Markel's Avatar
The first thing i would do is a pan drain, replace x 3 and a level check. lf you dont notice a difference after that, your issues are beyond fluid.
As for the fluid type, do yourself a favour and spend half a hour on google and make up your own mind.
mpsa
XK120 XK140 XK150
Jan 28, 2018 02:25 PM
jagtoes
Nov 14, 2017 09:59 AM
baxtor
Jan 12, 2017 11:36 PM
bt_bob1
Feb 28, 2014 01:08 AM
