XKR Issue after service at dealer.
Old Nov 21, 2010 | 02:22 PM
Campeon's Avatar
Default XKR Issue after service at dealer.
I posted this earlier in the xk section but realize that perhaps I should post it in this section.
A question for techs or anyone who may have experienced the issue I'm having with my 2004 XKR.
Last week I got a warning message saying "check rear lights" and "cruise control unavailable". I had read on this forum that it was probably the brake light switch so I brought it in to my dealer. It was indeed the switch and it was replaced. I also had the routine 50K (jag has 37K on her now) service done.
When I left with the car later that day it almost felt like the E brake was on but it wasn't. I then noticed that it stayed in first gear until over 5000 rpm before it would shift and then it would be fine until I stopped and accelerated again. I know, I should have returned to the dealer right away but I didn't.
I called the service manager and he suggested I disconnect the battery and then reconnect it after a few minutes to reset everything. Didn't help. It shifts fine in the sequential mode but not when I put in in "D" in the normal mode. The "S" button doesn't make a difference either.
I'm going back on Monday and they'll examine it and read any codes but right now I'm stumped.
Any ideas what went wrong?
Thanks all!
Old Nov 21, 2010 | 05:16 PM
Jagtec1's Avatar
The cars with the 6HP ZF transmission will not shift out of first if you have your fot on the brake pedal. It is likely that the car thinks the brake pedal is being pressed. I'd take it back to the dealer...sound like the switch is either bad, or was improperly installed.
Old Nov 21, 2010 | 06:28 PM
Campeon's Avatar
Post
Thanks so much Jagtec1. What you say just makes sense. I have an appointment first thing tomorrow morning and I'll let you know how that goes.
Old Nov 22, 2010 | 11:57 AM
Campeon's Avatar
Update:
After reading Jagtec1's recommendation I checked and noticed the brake lights were on all the time. Took it to the dealer this morning and they reinstalled the brake light switch and all is well. They also filled the fuel tank at no charge as a courtesy for my inconvenience.
Thanks again, Jagtec1.
Old Nov 22, 2010 | 05:13 PM
Jagtec1's Avatar
Glad I could help!
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Beardy
Sep 18, 2015 10:00 AM
obwoodie
Sep 3, 2015 07:45 PM
