XKR loud startup noise
Old Nov 8, 2020 | 02:22 PM
  #41
michaelh's Avatar
Originally Posted by keilwarm79
what do you mean by larger diameter getting around pulleys?
There is a flange on the alternator pulley, so when the belt rides up on it, the diameter of the pulley increases and effectively shortens the belt. The belt tensioner arm has to move to compensate for that. Once the belt drops back into the correct position, the tensioner arm snaps back to take up the slack.
I hope that makes sense!
There is a lot of lateral belt movement on the idler pulley, so it could possibly be a small misalignment of the tensioner assembly, but I'd go with Ekskaar's suggestion first and examine the idler and its mounting.
Check the mating surfaces are clean and give the pulleys a spin to ensure they're running free.
Alternator bracket is also a possiblility, but IMO not the problem here as the misalignment is happening before the belt reaches that pulley.
Holy F type
Oct 28, 2019 03:51 AM
avt007
Jan 23, 2015 08:17 PM
Lenoat702
May 30, 2013 06:51 AM
BlackVDP
Sep 9, 2010 08:11 PM
Prowler
May 6, 2010 02:06 PM
