XKR - When Did The Timing Chain Guides Go Metal
Old Jun 8, 2020 | 08:16 AM
crtfour's Avatar
Default XKR - When Did The Timing Chain Guides Go Metal
Good Morning,
I've been researching the threads on this issue, but I can't (unless missing something) find out when the tensioners went from plastic to metal. I will soon be taking my 2002 XKR with a 12/01 build date in to an indy shop to have the rear end leak repaired and would be a good time to have the tensioners done as it is outside of my area of expertise.
Sounds from the threads that if all else fails I could remove a valve cover and look.
Thank you,
Rob
Old Jun 8, 2020 | 08:33 AM
RJ237's Avatar
The build date is not relevant. Check the engine serial number. Metal tensioners began in 13 August 2001 with engine number 010813xxxx.
Old Jun 8, 2020 | 09:15 AM
crtfour's Avatar
Ahh good point. Where is the engine serial number located?
Old Jun 8, 2020 | 10:53 AM
crtfour's Avatar
I think I found some information on the number location ; may need to look in a couple of places.
Old Jun 8, 2020 | 11:15 AM
motorcarman's Avatar
Your engine number (later 4.0 V8) is aft of the left motor mount.
bob
Old Jun 8, 2020 | 11:26 AM
fmertz's Avatar
Listen to the experts, but I believe the parts you want are from the later 4.2l engines. The earlier metal tensioners, first generation after the plastic version, have also had issues of reliability.
Best of luck, keep us posted.
Old Jun 8, 2020 | 01:24 PM
The late 4.0 V8 used the 'silent-running-Morse style ' primary chains, sprockets, guides, oil pump etc.(From Engine (0108130000))
The secondary used the roller chains with the aluminum body tensioners.(From Engine (0108130000))
Old Jun 25, 2024 | 10:34 AM
MGracer999's Avatar
Not sure if this helps anyone but my car (VIN SAJDA41BX2PA25864) has the metal guides. Had my mechanic open the engine to check a couple weeks ago. We have owned the car since new and can confirm that we never replaced the guides.
xamyel
Jul 17, 2013 08:04 PM
xamyel
Jul 17, 2013 10:00 AM
tanngo
Dec 19, 2012 12:29 PM
tanngo
Jul 16, 2011 08:13 AM
xj8xj8
Nov 29, 2010 04:28 AM
