XKR/XJR-S oil/filter change... how often?
Old Oct 11, 2016 | 06:27 AM
NorJag's Avatar
Default XKR/XJR-S oil/filter change... how often?
Hi all,
I have an XKR 2006 and an XJR-S 1992. I have only clocked up 5 000km on the XKR and 400km on the XJR-S this season. The Jaguar dealer/service centre has advised that I change the oil and filter every year regardless of milage.
Any thoughts on this recommendation?
Thanks,
Mark.
Old Oct 11, 2016 | 07:48 AM
RaceDiagnostics's Avatar
I would change it in the XKR but not the XJR, I would leave that at least a couple of years.
Old Oct 11, 2016 | 09:58 AM
grantorino62's Avatar
Personally I would follow the dealers recommendation. Oil has a "shelf life" additives deplete over time. Every owners manual has an interval for time vs mileage. Same scenario with coolant and brake fluid.
Old Oct 11, 2016 | 11:13 AM
Mikey's Avatar
The oil type also plays a part with oil change. Synthetics can go two years dino is good for one.
Old Oct 11, 2016 | 12:21 PM
worrasf's Avatar
It's a no brainier for me in terms of cost/benefit.
I change the oil and all filters every March as part of the "new season service" and I do less than 5K miles/year - costs me less than £100
The mechanic jokes he uses the oil drained out of my car to put in his as it's so clean 😄
Small price to pay for peace of mind on this ageing engine
Old Oct 12, 2016 | 02:45 AM
Originally Posted by NorJag
...... The Jaguar dealer/service centre has advised that I change the oil and filter every year regardless of milage. .....
That is the official Jaguar recommendation. 12k Miles OR 12months - whichever comes sooner.
Old Oct 12, 2016 | 01:35 PM
lossking_'s Avatar
I change mine every 3k miles, but thats just me. Haha. I did yesterday. Easiest oil change on a car I've done. Didn't even have to lift it
Old Oct 12, 2016 | 02:22 PM
Matthew Chidester's Avatar
same here I change it every 6 months but I could probably extend it to a year.. and I don't drive very much.. I might be losing money but it's piece of mind.
Old Oct 12, 2016 | 02:55 PM
Seriously, an oil change after 250 miles, anyone think that the Jag recommendation may also be something to do with keeping their service dept busy.
I suggest the OP call the Jag service dept and ask if he should change the oil after 12 months and 250 miles.
My old 2002 TT had its oil changed on an 18,000 mile service routine and it was moved on with 130,000 miles on the clock, the engine pulled as good then as when I bought it.
It had a remapped 1.8l engine producing 265bhp and it was hammered every day.
Are the Audi engines just light years ahead of the Jag engines?
Old Oct 12, 2016 | 03:36 PM
Mikey's Avatar
Audi has the same annual oil change interval as Jag and every other OEM.
Old Oct 12, 2016 | 04:10 PM
michaelh's Avatar
Well, this could roll...
There is a rationale for changing oil annually even on low-usage cars, to some extent based on the assumption that most journeys will be of short duration where the oil doesn't reach temperatures that allow condensates to boil off and the potential for sludging is increased.
I stick to (max) 12 month intervals as mileage is typically low, and I freely admit to being 'old skool' and also that oil technology has moved on more than a little since I started buying it in the seventies.
If 3000 (or 300) miles gives you comfort then stick to it... mineral or synthetic
More banter than you can shake a stick at here: https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
Mike
Old Oct 12, 2016 | 05:12 PM
Gus's Avatar
Gus
I use synthetic and I go 6,000mi
Gus
www.jagrepair.com
Rapunzil
Oct 18, 2016 07:00 AM
Atlastajag1
Sep 8, 2016 09:23 AM
JimC64
Sep 5, 2016 11:46 AM
Tink
Sep 3, 2016 10:18 AM
StuG
Australia - Queensland
Aug 28, 2016 08:42 PM
