Help my 2000 S-Type is idling rough
po -> p0
then look them up using Search or get the free downloads here or on JagRepair.com - Jaguar Repair Information Resource
Also, move to S-Type forum.
All wires need to make good connections.
Have you changed the chain tensioners? Engine is on borrowed time if not.
Deeders33 (07-22-2016)
Replace coil on cyl #2 and check electrical connector to fuel injector on cyl #2 as well - make sure the plastic connector is fully seated on the injector. Coil location: (Passenger side of motor - 2nd cylinder from front of engine) also, if you have any frayed/burnt wires you have to cut the bad sections out and solder new sections of proper gauge wiring)
Received 2,579 Likes
+1 on the good advice above. Given the number of kilometres/miles on the vehicle, you may also want to replace the spark plugs, cam cover gaskets and spark plug boss seals.
If there is oil fouling of the ignition coil(s) due to bad spark plug boss seals, the coil(s) may need to be replaced.
Nookpad
03-26-2016 11:55 PM
01-19-2007 02:39 PM
01-01-2007 02:53 PM
