Help my 2000 S-Type is idling rough
Old Jul 20, 2016 | 08:34 PM
Deeders33's Avatar
Default Help my 2000 S-Type is idling rough
I have codes po 113, po302, po102 replaced mass airflow sensor but no change the connecting wires are frayed could that be the cause of poor idling it also surges when driving over 50 mph rpm tack jumps a tiny amount also. This is a 2000 s type v8
Old Jul 20, 2016 | 11:22 PM
MikeGC89's Avatar
Checked your coil packs? You may have an intermittent misfire.
Old Jul 21, 2016 | 12:17 AM
JagV8's Avatar
po -> p0
then look them up using Search or get the free downloads here or on JagRepair.com - Jaguar Repair Information Resource
Also, move to S-Type forum.
All wires need to make good connections.
Have you changed the chain tensioners? Engine is on borrowed time if not.
Old Jul 21, 2016 | 02:49 AM
Originally Posted by Deeders33
I have codes po 113, po302, po102 .....
1. I've moved your post from General Tech Help to S-Type forum
2. here's the extract from the Jaguar DTC lookup for the error codes:
See the possible causes for each of the codes in the right hand column.
Old Jul 21, 2016 | 10:00 AM
abonano's Avatar
Replace coil on cyl #2 and check electrical connector to fuel injector on cyl #2 as well - make sure the plastic connector is fully seated on the injector. Coil location: (Passenger side of motor - 2nd cylinder from front of engine) also, if you have any frayed/burnt wires you have to cut the bad sections out and solder new sections of proper gauge wiring)
Old Jul 21, 2016 | 12:29 PM
NBCat's Avatar
+1 on the good advice above. Given the number of kilometres/miles on the vehicle, you may also want to replace the spark plugs, cam cover gaskets and spark plug boss seals.
If there is oil fouling of the ignition coil(s) due to bad spark plug boss seals, the coil(s) may need to be replaced.
Old Jul 22, 2016 | 08:11 AM
Deeders33's Avatar
Thanks to all who replied I'm truely greatful for all your help! Make it a great day!
Nookpad
Mar 26, 2016 11:55 PM
warekito
Aug 9, 2007 10:02 AM
Jan 19, 2007 02:39 PM
Jan 1, 2007 02:53 PM
Nov 5, 2006 12:06 PM
