anyone know which fuse if for the right headlight?
RE: anyone know which fuse if for the right headlight?
Low(dip) beam Light Fuse
F16 mini Left Hand 20 AMP Yellow
F17 mini Right Hand 20 AMP Yellow
Engine compartment, 2nd row from the left of mini fuses. It'll be the 3rd(F17) and 4th(F16) from the bottom of that row.
Hope this Helps..
SpartanX
Hope this Helps..
SpartanX
Received 9,005 Likes
If your X-Type is pre 2004 it could also be the connector going to the bulb has melted. If fuse is ok, pull connector back off the bulb and look to see if it melted. There is a fix we do at the dealer by soldering new connector to it with a seperate ground soldered to the lamp casing.
ORIGINAL: SpartanX
Hope this Helps..
SpartanX
Hope this Helps..
SpartanX
that fixed it, thanks for helping a noob out
ORIGINAL: matl
ORIGINAL: SpartanX
Hope this Helps..
SpartanX
Hope this Helps..
SpartanX
Glad I could help...
SpartanX
Nice fix sparty...keep up the good work! Perhaps you also can get one of those snazy tech certified symbols below your avatar! In know I want one! There's another guy on here FJT that has had that problem and the dealer (i think) already fixed it once but it melted again...
ORIGINAL: aquill1
gunlocators
09-30-2015 08:05 AM
