replaced starter still won't crank
Old 01-12-2010, 02:08 PM
jasper's Avatar
Default replaced starter still won't crank
I just replaced the starter thinking it had a flat spot ( had to tap starter to get it to catch). Now with the new starter it won't crank. Battery seems to be ok. I can jump it at the solenoid and the engine will crank. When tried with the key the power pulsates, headlights go off and on the inst. panel flashes. any ideas???
Old 01-12-2010, 04:15 PM
85_305's Avatar
sounds like a bad connection or abad ground. Almost guaranteed. Check the bolts on the starter, battery , and body grounds
Old 01-12-2010, 05:43 PM
Has the battery been tested? I'm betting it's bad.
Old 01-14-2010, 09:11 PM
Strafe's Avatar
Was changing the starter hard? Do you need any special tools? Can a regular mechanic do it? or even a DIY?
Old 01-15-2010, 07:39 PM
jasper's Avatar
Thanks everybody. Finally got the battery checked, it was only 8 months old, it was bad.
I didn't think the battery would act quite like that. Thanks for the help.
Old 01-15-2010, 07:40 PM
Glad you were able to resolve it.
Old 01-15-2010, 07:45 PM
jasper's Avatar
The R&R of the starter went fairly easy. Just support the motor/trans when you remove the motor support. it covers the left side of the starter, can't come out with out removing it. there is just enough room to pull the starter out, back first with solenoid to the left.
Old 01-16-2010, 04:08 PM
Strafe's Avatar
Thanks Jasper!
Any other advice? I'm a DIY.
S.
JarodL
03-07-2024 01:39 AM
Charlene n John
09-28-2015 06:01 AM
Charlene n John
09-06-2015 11:03 AM
KarimPA
09-03-2015 07:32 PM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: replaced starter still won't crank
