Passenger side wing mirror replacement
Old 01-17-2014, 07:10 PM
NotTheLotion's Avatar
Arrow Passenger side wing mirror replacement
Can anyone tell me if I can either remove the glass that is cracked or replace the entire assembly all together? PLEASE help. I need answers
Old 01-17-2014, 09:10 PM
Dr dome's Avatar
You can remove the glass. BUT Be very careful of the center adjustment. There is plastic tabs that can easily break dead center of the mirror. Best thing is if the mirror is cracked pull from both edges while holding your thumbs in the center of the mirror.
Hope this Helps,
Good Luck,
The Dr!
The following 2 users liked this post by Dr dome:
NotTheLotion (03-14-2014), X2004 (02-05-2014)
Old 01-19-2014, 03:59 PM
ok, will I have to pull very hard? do I pull straight out or bend at the center? Do you know where I can get just the mirror? THANKS for this !!!
Old 02-13-2014, 07:20 AM
X2004's Avatar
You can get one for $53 at Genuine Jaguar Parts Online at Discount - Jaguar Replacement Auto Parts. I've just received mine.
NotTheLotion (03-07-2014)
Old 02-13-2014, 07:43 AM
X2004's Avatar
Here is the procedure:
http://www.mediafire.com/view/?j2ad10w101ln5pl
I found it on another post but have not performed it yet.
Old 02-26-2014, 05:37 PM
What did you look under to find it?
Old 02-26-2014, 05:38 PM
Ok great thank you!!! I will try it as soon as I can find another one.
Old 02-26-2014, 06:00 PM
I just ordered a mirror. Keep those fingers crossed for when I have to pull the bad one off.
Old 02-27-2014, 06:24 AM
X2004's Avatar
Enter your model, year, then go to: front door, outside mirrors, mirror glass. If it is the passenger one, you have to choose the one with the warning.
Good luck.
Old 03-06-2014, 05:07 PM
OK! I was just delivered the mirror. I looked over the removal steps again and I am going to proceed with the removal. wish me luck
Old 03-07-2014, 05:19 AM
X2004's Avatar
I'm sure you will succeed. If you could make a video of the replacement it would be great. There are a few on YouTube.
I haven't done mine yet, as it is still too cold up here. Instead, I have to deal with a chip on my windshield from a small rock that hit me yesterday Fortunately, I booked a mobile repair service through the internet and they're coming today to fix it while it's still manageable.
Old 03-07-2014, 10:46 AM
LOL! I just had the same rock incident happen yesterday and had it repaired. Small world Anyway, I just got done with the removal and installation. It literally took me like 3 minutes-including cleaning off the finger prints. Installing it warrants a gentle took on the outer edge. You have to put slight pressure on the inside edge while trying to snap back on the outside edge. You need to put your 4 fingers on the backside of the motors side clip WHILE using your thumb to push on the mirror to snap it back on. The reason I say use your fingers like this instead of just pushing on the outer edge is because the mirror may crack since you are pushing on the inner side at the same time. Does this make since?? Hope this helps someone else like others have helped me above
If anyone would like me to make a video of this, I will be more than happy to. Just let me know.
The following 2 users liked this post by NotTheLotion:
hproesel (12-16-2016), X2004 (03-08-2014)
Old 03-14-2014, 11:07 AM
X2004,
Have you done the mirror yet?
Old 03-14-2014, 01:33 PM
X2004's Avatar
I haven't yet. It's freezing up here and we are buried in snow. But my windshield has been successfully repaired.
Old 04-12-2014, 05:34 AM
X2004's Avatar
X2004,
At last,mirror successfully replaced!
The removal was easier than the install; I had to "play" a lot with it before it "clicked" into its spot. Altogether, it took 5 minutes. You have to insert the portion closest to the car first and then "push in" the portion farthest from the car.
Unfortunately, there was nobody available to video me doing it, but there are a few videos on YouTube showing how with other car makes.
Confused (08-01-2015)
Old 04-12-2014, 05:14 PM
xjscxkr3's Avatar
Jaguar wanted 1850 to repair mirror and motors. I got new motor and mirror because mirror mounts broke out with mirror and trim cap when it got hit.
I bought them myself and installed it but didn't know how to snap it in until I found this thread. Then it took about one minute. thanks so much. Also only cost about 350.
Old 04-20-2014, 07:53 PM
YIKES! $350. I know its too late to say but there were whole side mirror assemblies on Ebay that cost $99. I guess for future reference....
Old 04-20-2014, 07:54 PM
Glad it was successful for you! I love it when a plan comes together
Guernz
01-17-2016 12:22 PM
Aranon
09-03-2015 07:56 PM
91xjscoupe
09-01-2015 12:01 PM
frankc
09-01-2015 04:41 AM
divingmom
08-25-2015 07:54 PM
Quick Reply: Passenger side wing mirror replacement
