DIY Tie Rod End Help
Old 02-17-2011, 12:17 PM
fabfive's Avatar
Default DIY Tie Rod End Help
Hey Guys/Gals,
I was in need of some help to replace my worn out passenger side tie rod end on my 2004 X-Type Sport. It is loose/easily moves back and forth.
I picked up the part, Got the tire off and didn't exactly know where to start, Can any of you help me out?
Thanks in advanced, I wanted to stay clear of my Dealership.
Last edited by JimC64; 02-17-2011 at 07:06 PM. Reason: we do NOT use alternative words for dealer here!
Old 02-17-2011, 07:08 PM
Received 9,005 Likes on 4,113 Posts
Firstly, I can't help you but someone who can will probably be along soon.
Usually tie rod ends are not that difficult to change, so should be easy.
I would suggest that if one has gone the others probably not in much better shape....as they don't cost much it'd be a good idea to change them as a pair
Old 02-17-2011, 07:58 PM
Razkid's Avatar
1. Loosen the lock nut on the inside end of the tie rod.
2. Remove the tie rod end retaining nut,
3. Drive a tie rod fork between the tie rod and the steering knuckle to break the tie rod free from the knuckle.
4. Bring the lock nut back until it just touches the tie rod. You don't want it so tight against the tie rod that you can't unscrew the tie rod. This is to give you an idea how far to screw the new tie rod onto the shaft.
5. Unscrew the tie rod and count how many revolutions you turn it before it comes off.
6. Install the new tie rod by threading it on the same number of revolutions it took to remove it. It should be up against the lock nut at this point.
7. Install the tie rod into the knuckle and tighten the nut. Someone else will have to tell you the amount to tighten the nut (If you have a torque wrench!)
8. Tighten the lock nut on the inside end of the tie rod.
9. Install wheel
10. Remove jackstand and lower the car.
11. Drive to the front end shop and have an alignment done.
Old 02-17-2011, 08:53 PM
Thermo's Avatar
Received 3,825 Likes on 3,144 Posts
fabfive, I would recommend using a tape measure to go between two points on the front steering linkage. This way, regardless of how the threads are made, by doing a length measurement, you can get things back to where they need to be the first time. I've had a few cars that drove better after replacing the tie rods and no alignment than they did with the bad tie rods.
Other than that, the above how-to is pretty inclusive and should get you on your way.
Old 02-18-2011, 09:46 AM
fabfive's Avatar
Thanks to both of ya for the help, Hopefully its warm enough over the weekend to get this done.
- FabFive
Old 02-18-2011, 10:19 AM
Humy's Avatar
hey dudes,
this is quite crazy as I jumped on the forum to look for instructions on replacing an outer tie rod end on passenger front side, and it was the first thread... weird
what a resource
Jagbag Firestone wanted to charge me $120 for 1 end and $70 labor. I found a pair of tie rod ends on ebay for $50.
Old 02-18-2011, 04:39 PM
Humy's Avatar
Any pics of where the tie rod end is on the front hubs? Inside and towards the rear, right?
Any other tool I can use other than a tie rod fork? Needle nose pliers work?
Old 02-18-2011, 04:52 PM
fabfive's Avatar
Humy, If you were closer we would be able to figure this out lol. I have the same exact issue, the right tie rod end.
I was checking out youtube and came across this, not the same car but just for an idea:
http://www.youtube.com/watch?v=TYIDz...feature=fvwrel
Good Luck Bro
- FabFive
Old 02-19-2011, 08:45 AM
Razkid's Avatar
You can borrow a tie rod fork from AutoZone. You pay a fee but get it back when you return the tool. This is the easiest and quickest way to remove it without risking damage to the knuckle.
Old 02-19-2011, 05:49 PM
Humy's Avatar
funny story about autozone. i borrowed their piston tool when changing the Jags brakes. but the f'n passenger rear caliper turns counterclockwise, no tool for that!
Old 02-25-2011, 05:19 PM
Humy's Avatar
anyone know how many lbs of pressure? I can use my torque wrench if needed
bamforp
09-26-2021 08:04 AM
captbob73
10-24-2015 05:49 PM
thedugger1
10-16-2015 10:18 PM
JagBrian
09-21-2015 07:17 PM
JagLove86
09-06-2015 10:36 PM
Quick Reply: DIY Tie Rod End Help
