resonator removal
Old 09-26-2014, 04:19 PM
Ken Higgins's Avatar
Default resonator removal
I just removed the rear 2 resonators and the sound is a great but subtle improvement. Although, now the temp gauge in now stuck in the hot position. Any thoughts?
Old 09-26-2014, 06:27 PM
JTsmks's Avatar
Go pull the plug on the sensor to the gauge and see if it comes off full hot. If it does then it's the sensor grounding out and will require a new one. They are pretty inexpensive.
Old 09-27-2014, 06:52 AM
That sounds logical-where is the sensor?
Old 09-29-2014, 10:43 AM
mgb4tim's Avatar
I had to remove my rotted rear resonators and now the droning inside is not pleasant.
I'm thinking of pulling the front resonators and moving them to where the rears were over the winter.
Old 09-30-2014, 12:50 PM
dagny747's Avatar
Just wondering, both of you have US spec cars. So, don't you have 2 sets of cat's (downpipes and then under the seats)and then resonators at the rear. I had started another thread and am looking at removing all cats and just having pipes from the headers down and resonators on the rear.
Old 10-01-2014, 06:57 AM
mgb4tim's Avatar
Yup, 4 mufflers, 4 cats. A visual state inspection will require the exhaust to exit through a cat. when the discretionary cash and time find me, I'll removed the center mufflers, second cats, and add new aftemarket mufflers to the rear.
Old 10-04-2014, 10:07 PM
Nemesis's Avatar
Wow I did not know there were 4 cats on the us xj6 hmmmm. might just take the other two off (down pipe). As right now I am running those, dual pipe out the sides in front of the rear wheels with 18'' glasspacks. I used to have it un-muffled under the seats but it was a bit annoying however very race-ish .
Old 10-08-2014, 08:16 AM
mgb4tim's Avatar
I Pennsylvania, you can't exit the exhaust in front of the rear wheel unless it came from the factory like that. I tried that on my old Ranger, and it wouldn't pass the safety inspection.
Old 10-08-2014, 07:42 PM
Nemesis's Avatar
Hmm that doesn't seem right, I mean If you're running full exhaust why should it matter? Guess it kinda depends on who's inspecting it most in MD aren't very nice!!!
Old 10-09-2014, 07:35 AM
mgb4tim's Avatar
their fear is that exhaust fumes will go back into the car via the door windows
Old 10-09-2014, 04:11 PM
Nemesis's Avatar
pshh how cheap lol.
Old 10-10-2014, 11:42 AM
dagny747's Avatar
I tried it but I kept burning my leg when I got out of the car;-)
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
Daim
11-28-2016 09:28 AM
mrsimpson
09-15-2015 01:10 PM
SeanU
09-14-2015 04:31 PM
Quick Reply: resonator removal
