Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
LinkBack Thread Tools Search this Thread
Old 03-26-2010, 07:07 PM
Default Keys locked in trunk
i locked my keys in my trunk, any way of getting them out?
Old 03-26-2010, 07:26 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
Send a message via Skype™ to Gus
Quote:
Read this it should help http://jaguarforums.com/forum/showth...t=34601&page=2
__________________
Gus
www.jagrepair.com
XK8 1999 126,000mi K&N Filter, S-Type 2000 3.0 101,000mi K&N Filter
Insanity: doing the same thing over and over again and expecting different results.-Albert Einstein
“I fear the day that technology will surpass our human interaction. The world will have a generation of IDIOTS.” – Albert Einstein
Old 03-26-2010, 08:17 PM
what am i supposed to push on on that diagram?
Old 03-26-2010, 08:34 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
What it all means is that you remove your license plate and behind it you will see a circular sticker over a hole, open it. What Newuser is saying is that he used a flat screwdriver and pushed lightly on a small metal tab and the trunk opened.
You may need to read the entire post to understand further.
__________________
Gus
www.jagrepair.com
Old 03-26-2010, 08:41 PM
unfortuneatly, my car does not have the hole that is covered by a sticker. all i have are 4 small holes where the license plate attaches to
Old 03-26-2010, 08:46 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
I must assume that the car doors are locked? What year is your car?
__________________
Gus
www.jagrepair.com
Old 03-26-2010, 09:25 PM
my car is a 1998. My doors are unlocked, but my trunk button does not work
Old 03-26-2010, 09:31 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
I will look at my 95 and see what it has. I am not sure what to tell you at this point.
__________________
Gus
www.jagrepair.com
Old 03-26-2010, 10:13 PM
Thanks Gus for all your help on this issue, and the misfire issue. i replaced all my spark plugs and the car runs perfect again. I have a spair set, but i cannot get ahold of them until tomorrow so it is fine if i cant get them out, but i just wanted to get them out early so i could drive
Old 03-28-2010, 10:34 PM
The hole is where the screw for the license plate would go (bottom right). You have to remove the plastic piece that has the tread for the screw and once removed there will be a small slot. Note, my car didn't have the hole nor the plastic piece either because it was removed and painted over and the paint was covering the hole! So i just poked the hole with my finger to remove the paint and there it was. If you need details on how to get it open read what I did on the link above or email me.
__________________
2001 XJ8
Old 03-29-2010, 11:00 PM
Or... go buy a key from the ******* and then you will have one next time you do the same stupid thing.
__________________
Ross
Old 04-05-2010, 09:36 AM
tjcpt1
Locked my keys in trunk 2000 XJ8. Called locksmith. After 2 1/2 hrs of messing up my trunk release switch to the right of the steering column he said he would have to go through the back seat, or, drill the lock. I went into panic mode, and told him to hold off until I checked the forum. I found the 'behind the license plate' fix on the forum. In short, I taught him how to open the trunk of a 2000 XJ8. My car had a horizontal oval window to the right license plate screw hole. I popped out the plastic on both sides, flashlight to the left hole, screwdriver to the right hole, went fishing and "pop", the trunk opened. If you try this method, be patient, it WILL work. Because of the double lock when the alarm is armed, drilling the lock won't help, it will only ruin your lock. Trying an external power source to the inside trunk release switch risks computer damage/confusion and also does not work. Save yourself some time and money by doing it this way yourself. You can do it. Do not pay a locksmith or a dealer for a method you can do in 2 minutes. They will do the same thing and charge you hundreds of dollars. This forum is the most valuable tool a Jaguar owner can have. It works by asking questions and by posting our fixes. If you have a question on this forum and you find an answer like I did, make sure you post your fix so others can gain from your experience.
Tags
01, 1998, 2008, 2010, car, jaguar, keys, ljaguar, locked, trunk, type, xj, xj8, xk, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
