XJ40 ( XJ81 ) 1986 - 1994
HELP!! Loss all power
Old 02-08-2015, 02:25 PM
smgdata's Avatar
Default HELP!! Loss all power "fixed"
As I was driving down the freeway right now at 70 miles an hour in the rain my Xj12 lost all power all I have is lights and windows and that is it, no radio nothing no instrument cluster nothing.
What the hell happend? Any ideas.
While I wait for the tow truck.
Old 02-08-2015, 06:41 PM
smgdata's Avatar
Thanks to Sarcs help. I have located the ignition relay and was able to tape it together to get ignition and start the car and drive but that doesn't seem to be the full problem.
I've noticed that I don't have low and high beam headlight control.
And I'm getting a fuse 2 error but all of the fuses seem to be okay
Old 02-08-2015, 07:07 PM
manwich66's Avatar
Default Thankfully you're ok!
Been down that (stopped on)road before,NO FUN!Now I always pack a cheap test light in the car,spare relay,paper clips,bits of wire,etc.
To me,it sounds like loose major electric,battery cable or something.
Bang in the road?
Hopefully will be ideas soon
Good luck!
Old 02-08-2015, 09:36 PM
Jagfixer's Avatar
Check alternator output and check grounds and battery under load.
Old 02-08-2015, 11:54 PM
smgdata's Avatar
one of the blue 3amp fuses was blown.
I can't believe that fuse caused all those issues.
Old 02-09-2015, 12:05 AM
smgdata's Avatar
fuse A5
doesn't say this on the fuse panel.
but in the v12 manual
says
lighting logic
ignition on relay !!!
radio memory
Old 02-09-2015, 05:03 PM
Sarc's Avatar
So are you back in business ?
It sounds like the ignition relay went haywire and shorted out, blowing the fuse...........
Old 02-09-2015, 05:54 PM
smgdata's Avatar
yep all is good.
thanks for your always mountain of help
Don B (02-10-2015)
Old 02-11-2015, 07:04 PM
Sarc's Avatar
I could say that you probably knocked or damaged the relay when you fitted your stereo, but that would just be cruel stone throwing due to V12 jealousy on my part :-)
smgdata (02-12-2015)
duecedriver
12-25-2015 11:47 AM
thedugger1
10-16-2015 10:06 PM
tiger4366
09-22-2015 09:20 PM
Johnken
09-15-2015 05:46 PM
Wolfy
09-11-2015 06:27 AM
Quick Reply: HELP!! Loss all power
