Engine Coolant Level Sensor
Coolant Expansion Tank Vehicles Without: Supercharger
Open the engine compartment and fit paintwork protection sheets.
Ensure that the cooling system is cool and very carefully, remove the pressure cap.
Place a cloth under the expansion tank to absorb any spillage caused by disconnecting the hoses.
Release the hoses from the expansion tank.
Release the hose clip (expansion tank to thermostat housing hose). Disconnect the hose from the expansion tank and remove the clip.
Release the hose clip (expansion tank to radiator, air bleed hose).
Fit blanking plugs to the pipes and the tank.
Remove the expansion tank from the mounting.
Remove the bolt which secures the tank.
Remove the tank from the rear mounting grommets.
Disconnect the coolant level sensor connector.
Remove the expansion tank from the vehicle.
Use a pipe clamp to clamp the bottom hose branch.
Release the pipe clip and move it along the pipe.
Disconnect the tank from the bottom hose and remove it from the vehicle.
Empty any surplus coolant from the expansion tank into a drain tray.
Remove the cloth from the engine and clean any spillage from the engine bay.
Remove the coolant level probe.Use a lever to release the probe from the expansion tank and remove it.
Installation is the reverse of the removal procedure.
If you are only changing the inserted sensor on the bottom outside of the expansion tank, then no need to remove the tank and hoses. You will have to disconnect the tank from its bracket, but the hoses can stay connected.
There is no coolant loss when replacing with this method. The sensor does not sit inside the tank itself.
The sensor is inside a glass tube that is very susceptible to breakage when removing without removing the reservoir. Breaking the old one that is going into the trash is not a problem but be very careful installing the new one. It just snaps in place.
The last reservoir I replaced, one directly from a dealer parts counter, had the sensor permanently attached to the tank with some kind of adhesive. That tank will have to be replaced should the sensor fail.
Received 2,183 Likes
That was exactly my situation. I bought a new sensor and installed it. Still didn't work. Got a new tank and everything was fine. If anyone would like to purchase a new sensor, I have one for sale
No ......................................... but yes :-)
(see post #4 here : https://www.jaguarforums.com/forum/x...eplace-129460/
mrobinson (11-29-2014)
KarimPA
09-03-2015 07:32 PM
