rear view mirror aftermarket replacement
Old 08-01-2014, 07:02 AM
mrobinson's Avatar
Default rear view mirror aftermarket replacement
Hi,
I need a new rear-view mirror ( HNC3133AB ) and I'm wondering if there's a less bulky aftermarket replacement that'll do the same job?
I assume there won't be as it controls the headlights, but figured there's no harm in asking.
<- the factory one is pretty bulky
Old 08-01-2014, 08:00 AM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
I just replaced the R/view mirror on my 1998 xk8 conv. due to the defect issue. I puchased one with a $100 core charge from Coventry for $195. Looks like it is brand new. Let us know if you need a tel number or anything. BTW: save yourself time. Take a look, count the number of wires on the connection write down the connector's color. This is needed to send you the proper replacement. John
mrobinson (08-27-2014)
Old 08-01-2014, 08:37 AM
mrobinson's Avatar
I've got a quote for a like-for-like replacment from a breakers yard for £60 inc delivery, so I'll just buy that if there's no better aftermarket replacements.
Old 08-01-2014, 08:56 AM
batroute's Avatar
https://www.jaguarforums.com/forum/x...acement-17719/
Any help?
The rear view mirror with headlamp sensing option is unique to Jaguar. If you are fitting a second hand unit just be aware that it probably is the failure prone liquid type.
Old 08-27-2014, 05:25 AM
mrobinson's Avatar
I ended up getting a replacement from a breakers yard for £59 delivered. Well, two, because the first they sent me had the same problem.
I managed to smash my windscreen removing it. Ooops. Got that replaced on the insurance. Anyway, it's all in now, and I have a brand new windscreen.
Thanks for your help.
Old 08-27-2014, 07:44 AM
weisberg's Avatar
Question Slightly loose rear view mirror fix?
My rear view is slightly loose. When I set it into position, it stays there for a while but eventual slips down a bit so my view changes to that of the sub-woofer below the rear glass.
Suggestions to tight that up?
There is a ring that has fallen out of it onto the post. To prevent it from rattling, I wrapped it with a bit of black tape.
As I understand, removing the mirror can be tough.
Do we have to have a rear view mirror in the USA if we instead have a rear view camera display in the navigation screen full time?
Old 08-27-2014, 08:15 AM
scottatl's Avatar
Hello MRobinson,
Do you know if they have any others at that price that will sell and ship to US? I no longer have my original unit so cant get it fixed.
Old 08-27-2014, 09:11 AM
mrobinson's Avatar
I got the impression they had plenty. Here's their website - they have an international number listed.
Jagbreakers the best place for quality used and new Jaguar Car Parts and Spares
enderle (08-30-2014)
Old 08-27-2014, 10:09 AM
mrobinson's Avatar
By the way, the metal catch that holds the mirror in place was slightly damaged before it got to me, I assume in the removal process at the breakers.
I had a windscreen firm install it for me after I broke my windscreen removing the old one, so they put some windscreen adhesive behind it to keep it in place.
Old 08-28-2014, 08:25 AM
batroute's Avatar
Originally Posted by scottatl
Hello MRobinson,
Check the stickies at the top of the page for alternative part numbers - the Acura mirror is an almost exact replacement with an improved swivel joint and gel pack dimming unit
Old 08-30-2014, 01:10 PM
davidsonce's Avatar
What stickies are you referring to? I'm new to the forum and don't see anthing matching that description at the top of the page.
Thanks.
Old 08-30-2014, 02:00 PM
batroute's Avatar
Thanks.
https://www.jaguarforums.com/forum/x...e9/#post932835
Have a look at my post - should all become clear :0)
davidsonce (09-01-2014)
Old 09-01-2014, 12:59 PM
davidsonce's Avatar
Thanks. That clears things up. What threw me, as a new forum member, was the reference to stickies. I think I've figured those out now.
Old 09-02-2014, 04:58 PM
sharay38's Avatar
Sybesma's Electronics (800-456-4265) repairs your original mirror. They replace the liquid with a gel, so that self-dimming is not likely to fail again. Cost is $97, and when they returned the mirror to me, it looked brand new.
Old 09-03-2014, 03:59 PM
bradstuff's Avatar
Default Replacement Rear View Mirror
I too used Sybesma's Electronics (800-456-4265) in Michigan when my rear view mirror failed with brown streaks running through it. Their service was fast (i week turnaround) Call them for a service number and then send it to them.
Mine came back looking like a new mirror and it works great! Just be extra careful removing the mirror....you can break your windscreen.
Sabrinaservicewriter (03-17-2023)
fast40driver
04-19-2024 07:24 AM
frankc
09-01-2015 04:41 AM
rwoodlin
08-29-2015 04:32 PM
Goncalo Proenca
08-29-2015 06:22 AM
dpappyp
08-27-2015 06:31 AM
Quick Reply: rear view mirror aftermarket replacement
