xk8 fuel flap wont lock!
Old 04-01-2011, 01:18 PM
adriano70's Avatar
Default xk8 fuel flap wont lock!
Hi,
I have a 1998 4.o litre xk8 coupe and today went to fill up at the garage when the latch on the fuel filler flap wouldnt release at first but then wouldnt lock. It looks like the little latch on the body itself is broke. Im wondering can i just stick it back on? Any suggestions are greatly appreciatted.
Old 04-01-2011, 02:38 PM
itspec60's Avatar
Do you mean the plastic catch on the filler door? If so it can be purchased. Welcome to the forum.
piju1945 (11-20-2015)
Old 04-01-2011, 02:47 PM
Reverend Sam's Avatar
Received 1,259 Likes on 564 Posts
The release mechanism is very easy to get to from inside the trunk. Just pull away the trunk liner on the left side and you'll see the mechanism right there. Of course, if it's the plastic catch that itspec mentioned, then you don't even need to do that.
Can you post a picture of the part that broke?
Old 04-01-2011, 02:49 PM
adriano70's Avatar
Hi,
Its the latch on the body itself not the flap. I have taken a photo of it and will put it as my profile picture.
Thanks again,
Adrian
Old 04-01-2011, 02:55 PM
adriano70's Avatar
Hi,
I've tried to up load a photo but I've been denied by the site because ive only registered. The latch on the flap itself seems fine.
Thanks again guys
Old 04-01-2011, 03:02 PM
I just went and looked at the one on my car. Normally I would suggest super glue for something like that, however you'd have to be REALLY REALLY REALLY REALLY careful not to get any glue on the outside of the little plastic plunger thingy. Because then the plunger would get stuck and it would probably never work again. I'm a tinkerer, and if that happened to me, I would take the mechanism out from inside of the trunk, disassemble it, and try to glue that little piece back on with some special plastic epoxy. I forget what the epoxy is called, but you need the stuff that is specifically made for plastic. It has a really strong smell and it will make the whole house stink. I actually kinda like the smell, but my wife makes me use it in the garage. I can only use it on the weekends because I end up sitting out there drinking beer and sniffing glue for hours.
Old 04-01-2011, 03:52 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
If you would rather just replace it, it is pn HJA3093BE ($69.00 list) for the latch assembly and pn HJA3108AC ($2.00 list) for the plastic nut.
Old 04-02-2011, 06:02 AM
adriano70's Avatar
Hi reverned sam and thanks. I will have a look at gluing it with epoxy resin. Thanks for all the help and the advice on the glue sniffing.
Adrian
Old 04-03-2011, 04:21 PM
steven300's Avatar
i had the same problem with a loose unit.i used a clip to secure it.and while i was in there i drilled a small hole in the lever and atatched a pull wire so if unit ever fails i can open the trunk and pull the wire for gas door..tah-dah..steve
JagXK82001 (04-03-2011)
Old 04-03-2012, 08:43 PM
Judi in Alabama's Avatar
I'm having the same problem with my 1997 XK8. I can't open the fuel latch.
Old 04-03-2012, 11:31 PM
If you open the trunk you'll see a stiff fabric liner on the left side. You can pull it away and see the latch mechanism up near the area where the fuel filler door is. There's a small handle on the latch mechanism that you can pull backwards to manually open the door. If it works by pulling on the handle, but it doesn't work when pushing the button, I'd have to assume the solenoid in the latch mechanism has gone bad or there's an electrical problem between the button and the latch.
Old 04-04-2012, 05:28 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Originally Posted by adriano70
......... It looks like the little latch on the body itself is broke...........
You're in Flintshire?
If a repair doesn't work out, one of the specialist UK Jaguar breakers will be the lowest cost option for a replacement latch.
Old 10-27-2012, 06:54 PM
midamdoc's Avatar
Default Fuel door latch
White XKR : where do I find the fuel door plastic latch for '99 XK8 and what is the part number please? I tried gluing mine but pressure when installing it is too great even for epoxy.
Old 10-27-2012, 08:51 PM
WhiteXKR's Avatar
HJA3097AD
1999 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
Old 12-14-2012, 08:40 AM
Pete The Feet's Avatar
Unhappy Fuel flap
Hi,
Did you manage to sort out your fuel flap? I have exactly the same problem with my XKR. Be greatful for any advice.
Peter
Old 08-25-2021, 09:04 AM
paperclip's Avatar
This happened to my 2003 XK8 recently. It's an easy fix except that the plastic nut that holds the retraction mechanism in place seems to be unavailable from online Jaguar parts suppliers, including Jaguar UK, except for a very expensive one on eBay that might be 3D printed. I managed to glue the broken part of the nut using Loctite Plastics Bonding System glue and so far, so good.
DavidYau (08-26-2021)
Old 08-25-2021, 09:15 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
Keep those fuel door plastic lock pins well-lubed with lithium white grease. Doing so will protect them as they slide back and forth (and keep them much less likely to break)....
Old 08-25-2021, 10:49 AM
paperclip's Avatar
Good suggestion. Thanks!
99xk8guy
06-05-2023 06:28 AM
99xk8guy
09-21-2019 07:34 PM
Razor
08-28-2019 08:34 PM
dsnyder586
04-04-2019 02:38 PM
1100me
09-07-2015 06:26 AM
Quick Reply: xk8 fuel flap wont lock!
