Part load breather
Old 09-27-2016, 01:38 PM
Dale Dunn's Avatar
Default Part load breather
Anyone tell me exactly what the part load breather consist of or where I can purchase one? I can find the hose but not breather. Right now I just have piece of plastic in valve cover glued to hose. I'm experiencing excessive oil use and oil in throttle body
Old 09-27-2016, 02:05 PM
xkrmaxer's Avatar
I think this is the one for your car:
Jaguar BREATHER HOSE PART LOAD - AJ84880
The "hose" is the part load breather. It gets brittle and cracks causing a vacuum leak.
Old 09-27-2016, 02:06 PM
xkrmaxer's Avatar
Actually, maybe the nipple itself would be considered the breather. Either way, the hose is usually the problem unless you have something unique going on. When you take the old one off, look into the hole that goes into the valve cover. Sometimes that little passage gets clogged. You can use a drill bit that will fit in there or something similar to carefully clear it out. Sometimes that hole gets clogged and caused excess oil to get sucked into the intake arm.
Old 09-27-2016, 02:15 PM
Dale Dunn's Avatar
I'm looking for the part that goes inside valve cover that hose hooks to. When I got car there was a gobbled mess where hose hooked up. Looks like hose and fitting were broken and all patched together
Old 09-27-2016, 02:27 PM
xkrmaxer's Avatar
Ok, so it sounds like you are looking for this:
I always thought of that as part of the valve cover, but it does have that o-ring, so hopefully you can find it separately. Maybe someone has a part number for it. If you can not find it you can always buy a used valve cover on ebay for about $100
Old 09-27-2016, 03:20 PM
Dale Dunn's Avatar
That's what I'm looking for but can't find or figure out exactly its purpose even tho I know what it is
Old 09-27-2016, 03:48 PM
Paul Pavlik's Avatar
The Part Load Breather is a calibrated orifice (3/32" diameter) that acts as a PCV Valve. It draws Crankcase Vapors into the intake plenum vacuum (after the Throttle Plate).
Red Devil (11-20-2020)
Old 09-27-2016, 04:04 PM
Dale Dunn's Avatar
I have not pulled valve cover yet but plastic part that is broken in cover is 1/4" id. That was siliconed to piece of pipe that was siliconed to hose
Old 09-27-2016, 05:23 PM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
If you down load the SNG barratt catalog and take a look at the camshaft cover parts it show the part load breather is molded into the camshaft cover. In order to fit a new part load breather hose you will have to replace the left camshaft cover.
Old 09-29-2016, 12:44 PM
Dale Dunn's Avatar
Sng Barrett shows part but says no longer available. Can find part # in several places but no part available. Can something be fabricated that will serve same purpose? Concern is excessive oil use and oil in throttle body
Old 09-29-2016, 01:55 PM
xkrmaxer's Avatar
The inside does not usually get damaged as far as I know. If you make sure the little hole is not clogged (you can clear it out with a small drill bit if it is) then all you should need is an air tight connection to the part load breather hose. That should theoretically function the same as stock. You should be able to make something that would work pretty easily depending on how exactly yours is damaged.
Or just buy a used valve cover, this is just an example, you can probably find cheaper:
1999 XJ8 XK8 Jaguar Valve Cover Driver Oil Fill Side 4 0L Good Condition | eBay
If you need to do the tensioners anyway then I would replace the valve cover.
If the hole was clogged it could have been the cause, or at least a contributor, of excessive oil into the intake tube through the full load breather hose (this is my understanding based on reading the forum before cleaning this out myself, hopefully someone more knowledgeable can confirm that).
Old 09-29-2016, 06:28 PM
Dale Dunn's Avatar
I think I finally figured it out. Removed plastic pieces that were put together to replace part load breather, filled them with silicone and tomorrow once it's all dry I'll drill out to 3/32th and I should be good to go. (I hope)
Old 02-10-2020, 06:56 PM
2001 White XJ8's Avatar
Some additional information about the part load breather for anyone referencing thread. The part load breather is pressed in to the valve cover. They used a little bit of sealant to make sure it didn't leak. It is very difficult to remove but it is possible if you are careful and patient enough. It is fairly easy for this orifice to get clogged on higher mileage engines. A normal 2 inch long 3/32nd drill bit is sufficient to clean it out. Be careful not to drop the drill bit inside.
Old 02-11-2020, 08:55 AM
CorStevens's Avatar
for some reason there is a cutoff on later VINs for the periodic cleaning out the orifice with the drill bit. mine is after that cutoff. do not have any problems. note that on any car with a perfectly working crankcase ventilation system there will be some oil in the intake manifold. it is my opinion that the engineers assume this and allow it knowing that there is some lubricating quality and possible protection if any abrasive gets into the intake system.
DavidYau (02-12-2020)
Old 12-08-2023, 08:57 AM
DCHXK8's Avatar
Default part load breather
can someone provide a picture of this so I know what I am looking for? 1999 XK8 with intermittent starting issue. It will start and then stop. Cleaning the valve is on the "Hard start/non start" flow chart.
Old 12-08-2023, 10:50 AM
Received 7,879 Likes on 4,763 Posts
The maintenance TSB 600-03am3 shows the procedure.
michaelh (12-08-2023)
Old 12-08-2023, 12:07 PM
DCHXK8's Avatar
found it, thanks
kmeseck
09-13-2017 09:25 AM
DrDSP
09-15-2016 10:04 PM
Mjs128
09-12-2016 08:38 PM
dsnyder586
09-06-2016 04:28 PM
rjh
09-06-2016 02:19 PM
Quick Reply: Part load breather
