4.2 fuel rail
Old 04-05-2019, 05:30 PM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
Default 4.2 fuel rail
I've almost got the intake manifold off my 06 4.2, but not sure about the fuel line connection to the fuel rail. I pried the locking clip off and I think the line should just pull apart, but it isn't happening. Before I use too much force and damage something I thought I would check here.
Old 04-05-2019, 08:19 PM
Received 7,879 Likes on 4,763 Posts
The connection is a common Ford fuel line that needs a common tool.
The A/C and fuel lines use this type of tool.
Internet search for the special tool.
bob
RJ237 (04-06-2019)
Old 04-06-2019, 06:23 AM
RJ237's Avatar
So I finally get to use the release tool I bought several years ago for the fuel tank fittings and never needed. I had never seen this type of fitting up close before.
Old 04-06-2019, 06:26 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
Can you post a photo of that tool? I want to see if it looks like the fuel filter hose removal tool that I purchased a few years ago but have never needed to use....
Old 04-06-2019, 06:31 AM
RJ237's Avatar
Assuming it works I'll do that later this morning.
Old 04-06-2019, 09:00 AM
RJ237's Avatar
I'm embarrassed that I didn't think of the AC/Fuel Line tools last night. Simple when you know what you're doing.
The following 4 users liked this post by RJ237:
fmertz (04-06-2019), Jon89 (04-06-2019), kstevusa (04-06-2019), motorcarman (04-06-2019)
Old 04-06-2019, 02:48 PM
kstevusa's Avatar
Good job RJ, looks like the early 90's fuel line to rail connection. I've used my set a few time also. Just pull straight & easy :-)
Old 04-08-2019, 07:59 AM
fmertz's Avatar
Received 1,487 Likes on 1,043 Posts
Hmm, never knew that tool worked on that fitting. I ended up using that same tool further upstream on that same fuel supply line, somewhere by the inner fender. It has a more conventional layout (to me) and easily reachable. Thanks for the heads up.
Mike Badyna
11-12-2018 10:32 AM
Roger95
XJ40 ( XJ81 )
09-18-2018 09:15 AM
iconic
06-01-2016 11:44 AM
Jagalicious
06-19-2013 08:54 PM
Quick Reply: 4.2 fuel rail
