So Awesome...........But...The Radio - RESOLVED
Old 04-22-2015, 07:01 AM
xk8lattmaster's Avatar
Question So Awesome...........But...The Radio - RESOLVED
Just got my 2001 XK8 back from my mechanic, eight new coils, eight new spark plugs, all new filters, except for the K&N. Runs awesome, fast, holy mackerel,
yes it is. But, the problem I'm am having is with the radio, got a new battery last week, put it in, started right up, no problem, right ?, wrong !
My radio has not worked at all since I installed the new battery. Anyone have an idea why now power to the radio???????? Thanks for any help.
Last edited by GGG; 04-25-2015 at 10:10 AM. Reason: add 'RESOLVED' to thread title
Old 04-22-2015, 07:48 AM
jamdmyers's Avatar
Since you had the battery replaced and you were back by the amp check your connections there. Also check fuses (see chart) and lastly you have a US car so shouldn't need radio code, these are used mostly on the other side of the pond. You can find the owners literature in the DIY stickies to reference as well. You might also try a hard reset (disconnect neg battery cable, touch to positive post for 15 secs, then reconnect, don't forget to reset you windows)
File Type: pdf
xk8lattmaster (04-22-2015)
Old 04-22-2015, 11:56 AM
I was told that I would have to take the radio out, 45 min. job) to replace the fuses if that was the problem, do you believe this to be true? Thanks for the above help and I still need more, haven't tried the battery disconnect yet, but will
Old 04-22-2015, 01:10 PM
GGG is online now
Received 16,799 Likes on 12,168 Posts
Check Fuse #9 (10 amp) and Fuse #12 (5 amp) in the RH fascia fusebox for the radio and head unit. Fuse #9 (10 amp) in the Luggage Compartment fusebox for the antenna motor.
Old 04-22-2015, 03:42 PM
Lonestranger's Avatar
Exclamation Radio
Don't you need the security code for the radio? I don't know if they all use this security code, but I believe my 2006 XKR, with the alpine system requires such a code if disconnected. Just a thought.
Old 04-22-2015, 06:06 PM
Received 7,879 Likes on 4,763 Posts
If the radio head unit is set to EUR or AUST you might need a radio code.
If the head unit is properly set to US then it should NOT need the code if the radio loses power (ie. battery replacement).
bob gauff
The following 2 users liked this post by motorcarman:
Lonestranger (04-22-2015), xk8lattmaster (04-23-2015)
Old 04-24-2015, 07:00 AM
Well, I found the fuse in the trunk, boot, and it is fine, but I could not find the fuse box on the passengers side. It doesn't seem to be out in plain sight. If anyone knows exactly where it is , please let me know. I hate driving this awesome machine with no radio.
Thanking you in advance
perplexed
Old 04-24-2015, 07:12 AM
GGG is online now
...... I could not find the fuse box on the passengers side. It doesn't seem to be out in plain sight. If anyone knows exactly where it is , please let me know. ......
There's a colour coded plastic cover over the Fascia Fuse Boxes. LH one shown in this illustration:
The fuse positions are numbered but you need good eyesight!
Attached Thumbnails So Awesome...........But...The Radio - RESOLVED-fascia-fusebox.jpg
xk8lattmaster (04-24-2015)
Old 04-24-2015, 07:26 AM
Thanks Graham,
I'll look again tonight, is the box under the dash or between the dash and the floor?
I couldn't find it yesterday, but your illustration will help,
Thank you
Old 04-24-2015, 07:30 AM
GGG is online now
bob gauff
Bob,
A few years back with a UK spec X308 I was sorting out a radio issue. It would power on and then display "CODE _ _ _ _" (which we had) but then the radio still wouldn't tune in or play after the correct security code was entered.
It turned out to have been set to US and resetting to EUR fixed it. I therefore don't think the code locking is a feature of the Zone the radio is set to but must be hardware controlled such a a jumper or track on the board.
Old 04-24-2015, 04:31 PM
OK, I just replaced two fuses that were broken, one 5 amp and one 10 amp.
Radio came on, Hallaluya, but wait, I cna get all the stations, but noe sound.
so I tried to reset by pushing the tape eject button and the am/fm button at the same time, pushed buttons 1 thru 9 like I was told to do. Still noe sound. So, I tried a hard reset, disconnected the neg cable,turned the ignition to on, touche the pos pole for 1 seconds, then turned the ignition off and reconnected the neg cable.
Still nothing, WT? is going on here. Any one ????
Old 04-24-2015, 04:40 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Not all XK8s have it, but check fuse F18 in the trunk fusebox next to the battery. This is the 30A fuse for the power amp if your car has premium audio. (Remove the narrow floor panel in the trunk for access.)
Old 04-25-2015, 03:31 AM
GGG is online now
You did rotate to combined ON/OFF Switch + Volume Control knob clockwise .......?
Old 04-25-2015, 10:03 AM
Bloody hell
Thank you graham, I replaced the 30A fuse and the radio now works
my beautiful alpine stero system is now working in my awesome XK
THANKS TO ALL THAT HELP OUT, REPLACED 4 BURNT OUT FUSES
Rich
Old 04-25-2015, 10:14 AM
GGG is online now
Now that you're relaxing listening to the radio, you should give some thought to what blew all the fuses ........
Old 04-25-2015, 03:15 PM
wolfpck1's Avatar
am wondering if you gave someone a jump start and that maybe blew the fuses ? just a thought .
Old 04-27-2015, 07:01 AM
I believe it happened when I bought a new battery and installed itl
Paora
02-04-2021 12:36 AM
oldjaglover
04-01-2020 05:04 PM
philwarner
01-31-2016 09:36 AM
ziondio
09-28-2015 11:24 AM
Quick Reply: So Awesome...........But...The Radio - RESOLVED
