Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Harness Adapter for aftermarket radio with Premium sound system
Old Jun 21, 2010 | 09:56 PM
timmat1's Avatar
Default Harness Adapter for aftermarket radio with Premium sound system
I have an 01 Jag with a radio with the part number XR8F-18K876-CFAEK It has the premium sound and I was wondering if anyone knows where to get an adapter for the harness to adapt this to an ISO harness on my new aftermarket radio.
I know some people talk about some company in UK... does anyone know for sure what part number and what company to go with? Thanks for any help!
Old Jun 22, 2010 | 10:53 AM
rothe's Avatar
Metra is one manufacturer of such wiring harnesses. They're available from a variety of online retailers.
You can probably find a part number for the harness here:
http://www.metraonline.com/fit.aspx
Then search Google with the terms "Metra" and that part number.
Old Jun 23, 2010 | 11:55 PM
timmat1's Avatar
awesome... thanks for the lead!!!
Old Jul 28, 2011 | 06:07 PM
joyroadboy's Avatar
Default finding the adapter
did you ever find the adapter im trying to find one on my 02 xkr with premium sound system to install aftermarket radio
Old Feb 25, 2013 | 12:10 AM
kashaf's Avatar
Apparently it is the 70-9500 harness required. I have ordered one with the antenna adapter and a 6.2" nav system (that has support for front+rear cam, external microphone and steering wheel controls) from ebay. Cost $300 to canada including shipping.
I emailed the seller and he replied by saying sound will work except factory woofers wont work with this installation. My other concern is the steering wheel controls. Apparently theres a metra sw kit that can convert jaguar steering wheel controls to be used with any navigation unit. The wiring harness Metra 70-9500 however has a couple of leads coming out for steering wheel controls so i am going to try and install without the metra steering wheel adapter kit at first to see whether my nav connects directly.
Another concern is i wanted to replace on the licence plate tail lights with a camera+tail light but i can't seem to be able to find a rear view camera for the x-type.
Also my nav unit has input for front camera but i really dont see any use if a front facing camera and when i'd like it to be activated.
Old Feb 25, 2013 | 12:17 AM
kashaf's Avatar
Was searching forums came across this
http://www.installer.com/pdf/99-9500.pdf
Old Feb 25, 2013 | 03:42 AM
kashaf's Avatar
http://www.metraonline.com/files/pro...NST70-9500.pdf
Also found this on the harness no wonder we can't use car woofers because there is no connection for woofer. But my nav does support woofer. I wonder what the wiring is like from the jaguar end. Anybody have the wiring diagram for the radio connector for jaguar x-type?
Old Aug 7, 2018 | 10:03 AM
mikchek's Avatar
every find a solution?
Old Jun 19, 2019 | 08:25 AM
Cafcpete's Avatar
I used this in my XJR6 with premium sound and it works fantastically well.
https://incartec.co.uk/part-search?s=20-277
Which car are you wanting it for?
philwarner
Oct 4, 2024 01:37 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
jagent
Sep 12, 2015 01:40 AM
Mike Green
Sep 7, 2015 12:39 AM
