Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Not your typical CD changer question
Old Jan 11, 2011 | 07:20 PM
rhriczko's Avatar
Default Not your typical CD changer question
I was told when i bought my car that it came with a 6 disc changer, in fact there was a cd changer installed but not working. ( I did not buy it from a Jaguar dealer)
I bought a new CD changer and a link lead cable (Fiber optic) but it still wouldn't work. I took it to the dealer with everything connected as it should to have it programmed but the tech got an error message saying it could not be programmed.
The odd part is the CD changer has power, will load and eject the cartridge, but will not be recognized by the radio. (Everything in my car is stock)
I believe it may be that the car never originally came with a cd changer and the wire harness from the stereo to the cd changer does not have the correct wiring to make this work.??? This is just a guess but Im hoping someone with a little more knowledge on the topic can shed some light.
Are all wire harnesses the same or should I invest in a new one?
Old Jan 12, 2011 | 02:03 PM
rhriczko's Avatar
Oh, one other thing.
I tried hooking up a stock single CD changer in replace of my tape deck. It came out of an Xtype, Im not sure what year, but that also didnt work. Could it be the CD button on my radio? Or would the single CD player have to be programmed by the dealer too?
Old Jan 13, 2011 | 07:43 AM
rothe's Avatar
This is a long shot, but is it possible that your car has the Audio Control Module (ACM) installed, and the switch is in the ACM-on/changer-off position?
The ACM switch is usually mounted in the center console, but could presumably be mounted in the glove box or elsewhere. See my ACM page for a picture of the switch assembly, as typically mounted in the center console. http://www.jimrothe.com/jaguar/acm-bluetooth/acm.html
If it's not there or in the glove box, you might want to pull off the passenger's side floorpan-tunnel cover, and look for the ACM control module. It will be a 4x8x1 inch box with fiber optic cables and wiring running to it. There wouldn't be anything else like it in the tunnel.
Old Jan 13, 2011 | 08:41 AM
rhriczko's Avatar
Thats a good idea, Ill look for it. Two questions though, Is the ACM an aftermarket part or do all jags have them? and also What is the passenger side floor pan tunnel? Im not familiar with this but would love to give it a try.
Old Jan 13, 2011 | 09:28 AM
rothe's Avatar
Ummm... "yes and no" to your first question.
The ACM is built by an aftermarket company called Dension. They sell it through retail channels for other cars like Mercedes, among others.
Jaguar takes that same product and packages it as an option for some models. Some time late in the production run of these models, Jag started including it as standard equipment. I don't know the starting date for that change.
It wasn't standard equipment in 2002 on the X-Type. But that doesn't mean that a previous owner didn't have one installed.
The floor pan is the part of the car underneath the carpet in the passenger compartment. The tunnel is the hump that runs through the center of the car.
Seeing you ask this question, I'm going to suggest that you don't pull the tunnel apart to look for an ACM control module. Just stick with searching in the usual places for the switch assembly: the center console is the factory-recommended mounting place, and the glove box seems like a possible alternative. If you don't see the switch, you don't have an ACM.
Old Jan 13, 2011 | 10:24 PM
rhriczko's Avatar
Ok... It must not be a part of my car. Although, after looking in to it I think I may add this. I really like the idea of being able to connect my Ipod right into my console.
I still would love for the CD changer to work though. Especially since I invested money onto the darn thing.
Old Jan 13, 2011 | 10:35 PM
rothe's Avatar
On the one hand, having an iPod connection might suffice for you in lieu of a functional CD changer.
On the other hand, the ACM relies on the same connections and communications to the head unit that the CD-changer relies on. In other words, the ACM might not work until you get this other issue resolved.
I suppose you could try it, and if it doesn't work, you're back to square one trying to get your CD-changer to work. That might be an expensive experiment.
Old Jan 14, 2011 | 01:08 PM
rhriczko's Avatar
I agree, It's definitely going to cost $$$. lol. Thats what happens when you love a Jag. haha.
Old May 27, 2021 | 03:18 AM
SeanHath's Avatar
I've found a 'better than expected' solution to my woes. I didn't really listen to CD's so I've kept the broken dash mounted CD unit in place , and added a 'Jaguar AUX input via Wired FM Modulator Veba FAKRA iPod iPhone MP3 car adapter' from ebay user 'Incarconnections'. The whole thing came as a kit with adapters for the aerial input. You can switch the whole thing on and off - and other than the 3.5mm jack, there are no wires on show anywhere.
A little bit of farting around fiddling and I've now got my iphone connected to the car. The signal is wired, so crystal clear like a CD, and all for less than £50 !
https://www.ebay.co.uk/str/incarconnections?_bkw=jaguar
Forcedair1
Feb 19, 2020 01:51 PM
captbob73
Oct 24, 2015 05:49 PM
texaspete
Sep 10, 2015 08:34 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
YycXJS
Sep 7, 2015 09:58 AM
