E type ( XK-E ) 1961 - 1975
Detaching radius arms
Old Jan 13, 2024 | 03:46 PM
billb44's Avatar
Default Detaching radius arms
My etype needs a new universal joint which requires dropping the rear suspension. I have done this before and do not remember it being a big problem. This time however, I cannot release the radius arms (either one). The rubber attachments to the car body have withstood all the persuasion I can muster. Anyone have a suggestion?
Old Jan 13, 2024 | 04:23 PM
RedRider48's Avatar
Have you soaked, as much as you can, the area with PB Blaster or equivalent? They can be a very trying! Another consideration, let them soak in the penetrate while unbolting everything else and let some of the weight (gently) under a jack help. My first removal was similar to your experience. Before re-attaching them, I smeared anti-seize on the rubber. It helped years later.
Old Jan 13, 2024 | 07:29 PM
billb44's Avatar
Thanks for the suggestions. Yes, I have done a PB Blaster overnight soak. I have also removed all other connections and lowered the jack so the mounting rubbers were the sole support for the suspension. Have also used wood wedges to try to force the suspension off. No success with any of this. Have not resorted to explosives yet.
Old Jan 13, 2024 | 10:05 PM
RedRider48's Avatar
Maybe heat? Applied carefully.
Old Jan 14, 2024 | 02:24 PM
DaveAllen's Avatar
This might sound terrible, but it worked on my XJ-S... One side came of reasonably easily while other side was really stubborn. I used a lot of Kroil (my go-to fluid to penetrating fluid). The pry bar I use fits really well in the bushing and I've used it without issue to successfully remove trailing arms from several E-Types. I put all my might (not that there's much) to lever off the trailing arm. This was a lifting direction. I put a floor jack under the pry bar handle and put a little more tension on the pry bar. (I didn't go wild!) After an hour or so under tension there was a satisfying bang. The trailing arm came off with no ill effects. I think the tension applied over time helps the penetrating fluid do its job.
HTH, Dave
Old Jan 14, 2024 | 03:01 PM
billb44's Avatar
Perhaps the difference between my previous experience and this is that I am 10 years older and that is adding up. So more muscle it will be even if I have to draft someone. Thanks for all your inputs.
Old Jan 14, 2024 | 03:14 PM
olivermarks's Avatar
Use the right angle end of the middle one of these pry bars to walk it out. They tend to get covered in the rubber so don't use your good quality ones
https://www.harborfreight.com/pry-ba...ece-68339.html
Old Jan 16, 2024 | 09:35 PM
mxfrank's Avatar
I've had them rusted solid to the bosses. What I did was to use a torch to melt out the rubber (keep a hose handy). Once the arm was out of the way, I used a hacksaw and chisel to split the mounting cup, and then it just peeled off the boss. If you don't want to use a torch, you can cut the rubber with a hacksaw blade, but it's very slow work.
crateguy
Jul 4, 2021 12:26 PM
andycub
Apr 25, 2020 09:23 AM
jya
40
Jan 7, 2020 11:33 AM
JagsteRJX
Jun 17, 2017 12:07 PM
mhamilton
Nov 22, 2016 01:32 PM
