E type ( XK-E ) 1961 - 1975
Engine Noise
Old Apr 16, 2021 | 02:11 AM
Rodney Binley's Avatar
Default Engine Noise
Hi I am a new Etype owne,r or will be in a couple of days went for a test-drive in beautiful primrose V12 cab and noticed a noise when throttle blipped the noise at the end a cross between a wine and something catching at seed, I am not a techie but my Son in law, who is , was worried about timing chain but after he drove it said it was more likely to be exhaust, water pump, alternator. I fully expect noises on a 50 year plus lady but just don't want to dive in without knowing the depth
Old Apr 16, 2021 | 07:06 AM
nunzio66's Avatar
Rodney:
Welcome to the world of E-type ownership!
Regarding your strange noise: we can’t help you much based on what you’ve told us so far, so you’ll need to do some self- diagnostics.
Is the noise coming from the engine compartment or the exhaust? Does it vary with engine speed? With car speed? Do you hear it when the car is stationary?
If you can hear it when the car is stationary that will help you isolate it...use a stethoscope or even a piece of rubber hose to listen to various parts of the engine (being careful not to get caught in any rotating mechanisms).
You can also try to record a video and post it so we can listen to it.
Good luck!
Alan
N.J.
Old Apr 16, 2021 | 12:27 PM
Default Thanks Alan
Hi Alan
Yes I thought I was a bit light on info, have got the car now and we have isolated the noise to around the coil I have attached a video you can hear the sound which is more like a tuning fork, it some times last longer when the engine is being driven
Perhaps it is normal never having or driven Etype I would not know other than that the car runs a dream for a near 50 year old
I have attached video
Old Apr 16, 2021 | 02:08 PM
nunzio66's Avatar
Rodney:
I don’t see any video attached.
Alan
Old Apr 16, 2021 | 04:06 PM
Hi
Its only very short video but file size too big will do some work on it
Old Apr 16, 2021 | 04:12 PM
lrgridley's Avatar
If your coil is located on the front of the engine (later cars moved to back) you might want to check the emissions air pump that resides on the lower right front side of the engine. I've had one of those go bad and it made lots of unpleasant noises as it did. Try loosing the drive belt and so it slips freely and see if the strange noise goes away.
Old Apr 18, 2021 | 01:20 PM
Originally Posted by nunzio66
Rodney:
Alan
Hi Alan sorry for delay here is the link
The noise is like a loose washer rattling under a bolt It happens at 1100 revs at the beginning of the video I go through the revs and you can just here it then I hold it at 1100 revs and it is constant
Rodney
Old Apr 19, 2021 | 06:33 PM
nunzio66's Avatar
Rodney:
I can’t access the video...it says “this video is private”.
Did anyone else have any luck opening this clip?
Alan
N.J.
Old Apr 20, 2021 | 02:08 AM
Hi Sorry there is now a whole lot of checks before video is published its now public with link
Have been out in the car several times now really enjoying it in some very unbritish sunshine the car drive a treat other than this noise which does not seem to effect anything Although sunny its cold and heater does not seem to be functioning but that will be a job for the experts At the end of my short journeys I would just like to continue for n extended tour of Europe........One day !!!
Old Apr 20, 2021 | 07:50 AM
nunzio66's Avatar
Rodney:
Yep...I can hear the noise now. As you mentioned, it sounds like something is rattling, but it only happens at a very specific rpm. Loose or worn timing chains would be noisy throughout the rpm range so it’s something else.
Get yourself an inexpensive engine stethoscope and listen to various parts of the engine while someone (or something) holds the revs at 1100 rpm. Even a piece of rubber hose would suffice. You need to isolate the specific area that the noise is coming from. It may turn out to be something simple, like a heat shield resonating or vibrating at a specific rpm.
Anyone else other there have any ideas?
Keep us posted.
Alan
NJ.
Kee
Old Apr 20, 2021 | 12:31 PM
Hi Alan
Yes it is a bit of a mystery have found an Etype "expert" close to where I live so taking it to hime to have a listen and look
Rodney
Old Dec 21, 2021 | 05:12 PM
Robert3737's Avatar
Default Chirp Chirp sound.
[QUOTE=Rodney Binley;2379550]Hi I am a new Etype owne,r or will be in a couple of days went for a test-drive in beautiful primrose V12 cab and noticed a noise when throttle blipped the noise.
Hi I’m getting a chirp chirp sound at different rpm, car is stationary. Could be a blip blip sound. Question did your exhaust leak affect your idle smoothness?
Old Dec 22, 2021 | 09:44 AM
dibbyandco's Avatar
Above advice for identifying the noise of course are all good, but to be honest, I didn't hear any sound that would make me overly worried. Check things like oil pressure, temp etc when hot (REALLY hot, not just 15 mins round the block), amount of oil you use over (say) 400 miles, is it charging ok (normal alternator voltage check at about 1500 rpm), is it losing coolant; and if they are ok I wouldn't get too concerned. If you have a specialist nearby then by all means get them to listen, but don't go ripping things apart prematurely. Overall these engines are pretty solid affairs that don't fall apart readily!
I did a trip over the French and Spanish Pyrenees within a couple of months of getting mine!
Kev-P-
Jul 3, 2020 09:37 AM
Kirk Morey
Jun 11, 2020 07:40 AM
tbrian01
Feb 17, 2017 02:18 PM
Na5h
Feb 9, 2014 03:46 AM
afonda
Mar 17, 2009 07:22 AM
