E type ( XK-E ) 1961 - 1975
Full rebuild MK1 E Type
Old Nov 15, 2020 | 08:34 AM
RM9700's Avatar
#3 and #11 go together and are used in mounting the front anti-roll bar. Sandwiched between the bar and the front cross member assembly ( aka picture frame). #4 looks like a 2nd set of #3 . #13 looks like the bracket for securing the flexible front brake lines. It is mounted in between #3 & #11. There should be two..... a LH and a RH bracket. The one in the picture appears to be the RH side.
cheers, Richard
Old Nov 15, 2020 | 12:10 PM
Fraser Mitchell's Avatar
Originally Posted by phoenix1
Hi can anybody tell me if the wiper motor is fitted to any other car and not just Jaguar . Thanks. Bryan
The motor is a Lucas item and will have been fitted to many British cars. The differences centre on the rack, its tube, and probably the wheel boxes and the chrom-plated escutcheons on the top of the bulkhead. These vary according to the wiper location. E-types, for instance, started out with three wipers, then reverted to two, but the motor remained the same, but note that a permanent magnet motor was introduced by Lucas. This is easy to identify by its round from, compared to the square field-existed motor.
Old Nov 16, 2020 | 03:41 AM
phoenix1's Avatar
Yes mine has three wipers . I was wanting to know if I could source the motor elsewhere say British Leyland models etc . I know my 69 Mini has a similar one . Bryan
Old Nov 16, 2020 | 03:56 PM
I would say you can, but I'm not an expert. For instance, some cars have only single speed wipers, some two speed, and I'm not sure how that is dealt with in the system. If you can find a motor where all the wires and colours are the same as the one you have already, then it will be OK.
andymacsom1
Jul 11, 2018 09:40 AM
Jose
May 10, 2018 06:49 AM
loftymk1
Feb 26, 2018 03:01 AM
marmar1305
Oct 18, 2014 08:57 AM
michaelstill
Apr 18, 2014 09:21 PM
