E type ( XK-E ) 1961 - 1975
Fuse panel won’t fold forward
Old Dec 8, 2023 | 05:15 PM
Greg1967OTS's Avatar
Default Fuse panel won’t fold forward
Usually the fuse panel on an E Type Jaguar is simply accessed by removing the knurled screws in the upper corners of the instrument panel and fold the panel down. Mine refuses to move even an inch. All suggestions will be greatly appreciated.
Old Dec 8, 2023 | 08:47 PM
Valerie Stabenow's Avatar
Default Panel
Year and model always helps us help you.
that said, have you been able to lower it in the past? If so,, how long ago? Was there any work done in that area that might contribute to the problem?
here's a link that may help
https://forums.jag-lovers.com/t/e-ty...a-s1-car/99456
Old Dec 8, 2023 | 09:28 PM
billb44's Avatar
Sounds like the radio panel might interfere with the instrument panel where it hinges. Remove 2 bolts, 2 nuts then slide radio panel loose and check if instrument panel is free.
Old Dec 9, 2023 | 03:47 AM
dibbyandco's Avatar
I agree, radio panel can interfere. Has it moved at all or been distorted by some work?
Old Dec 9, 2023 | 05:23 AM
piper 888's Avatar
Must be the radio frame blocking the fuse panel and billb44 has the correct solution
Old Dec 11, 2023 | 07:57 AM
Dan219's Avatar
My 67 OTS has the same exact problem. It is the radio frame. Mine has been reupholstered and the material is slightly thicker than the original, causing a much tighter fit that doesn’t allow the fuse panel to rotate properly. You must remove the radio frame in order to access the fuses. There is a rubber seal at the base of the panel you may choose not to fold that in, this way there a little more room to open the panel. It worked in mine making it a little less challenging
Old Dec 12, 2023 | 10:36 PM
You are exactly right. It was the radio frame. My car was recently reupholstered as well.
Thanks so much for all the help.
Old Dec 17, 2023 | 08:46 PM
you are absolutely right. I removed the radio box and the panel opened up. Thanks for all the help.
TheMaitham
Jun 16, 2025 11:37 AM
JDog
Jan 28, 2023 09:24 PM
Paul68
Jan 25, 2022 11:12 AM
Cruzer56
E type ( XK-E )
May 18, 2016 06:30 PM
