Rusted floors
You can find the floor pans on eBay from time to time. https://www.ebay.com/itm/0558-5995-J...item33ada4f1cc (pretty reasonable and I've bought from this guy a lot).
I got my set from Welsh: https://www.welshent.com/Sheet-Metal...7002&ps=12&p=2 (a tad more expensive).
Rust grows and if visible will be beyond that point and need to cut back to good metal.
all new floors, transmission tunnel,
Trial fit of new wing and sill. Doors finally got here so can do fitting and get ready to weld!!
this OTS took some minor rear end damage that over the years rusted on through so entire bottom replaced.
Kind of a drawn out thread, but a reasonable amount of useful info: LNRB Floor Pan Adventure
Best of luck with the radiation therapy on the metal cancer. Am also going through more of the same.
Not sure why this is considered a drawn out thread......you all know rust is a critical issue with e-Types, and many thanks to those who have given me their case studies, referrals and guidance. I have not yet torn up the heavy rubber matting the previous owner had riveted to the floor to see excactly how much floor cancer there is, but while the pans are rusted are, the sills seem sound. Right now it’s in a mech. shop receiving new fuel tank and alum radiator.....so I can get the thing started. Once these systems are recommissioned I might then drive the car and bring it to a chassis master, when I could report to those who are interested, in bringing a 20 yr coupe that was parked (wet) and suffered greatly for it. Again Thanks!
Received 6,253 Likes
moronthethrottle (07-19-2018)
Sorry for the misunderstanding, as Norri states, not this thread, but the one I linked to. The linked thread travels through the entire process including learning how to weld! It is a good tutorial, but takes some time to work your way through it all. Just the nature of the forum beast.
I discovered rust under my rear seat. The first muffler is under there with a heat shield above it, then a layer of fiberglass insulation. Not a well thought through arrangement. Insulation gets wet, is then heated by muffler and rotted out the steel under the seat. Had it cut out, new steel fabricated and welded in a few nights worth of time. You would not be happy with my patch job in an E. Adequate for my common XJ6 daily driver as it was in a location that no one will ever see.
SNG Barratt USA (07-20-2018)
vdpnyc
02-17-2011 02:59 PM
jagxtypeboy
01-19-2008 06:52 PM
