¼ mile – 11.544 @ 124.24mph (2016 Coupe R)
Old May 7, 2018 | 09:38 PM
casper83's Avatar
Default ¼ mile – 11.544 @ 124.24mph (2016 Coupe R)
Stock other than rims/tires.
Old May 7, 2018 | 09:47 PM
EB77's Avatar
Very impressive run. Amazing what all wheel drive does for the drag times.
Old May 7, 2018 | 10:19 PM
Chawumba's Avatar
Well, AWD and another 50 hp and and 40 lbs torque and 125 lbs less weight if his current car is a coupe vs convertible.....
Old May 8, 2018 | 04:11 AM
Gibbo205's Avatar
For comparison my PB in my SVR so far is 11.28@124mph.
Old May 8, 2018 | 07:50 AM
yell03's Avatar
Congrats on a great run!
Cool to see the difference between a 495hp rwd and a 550hp awd
Old May 8, 2018 | 09:13 AM
Paul_59's Avatar
Banned
Be interesting to see the difference between R coupe rwd and R coupe awd
Old May 8, 2018 | 10:24 AM
Gibbo205's Avatar
If both on street tyres I'd expect the AWD to 60FT and ET quicker, but the R to have a marginally quicker terminal speed of say 1-2mph due to less transmission losses compared to AWD model.
Put the R on drag radials and it should then in theory win the race.
Old May 8, 2018 | 10:48 AM
DPelletier's Avatar
Yep
Dave
Old May 8, 2018 | 10:56 AM
DPelletier's Avatar
His V8S time was pretty slow; member mj1903 recently posted a stock V8S time of 11.77 at 121.29. ....and of course there is always MT's 11.6 @ 122 for a V8S
I'm not saying a V8S is quicker or as quick as an AWD R but the difference isn't as much as some think. ...the power is up on the AWD R by 40PS (510 vs. 550) but there is the additional weight and drag of the AWD system. I'm with Gibbo; quickest R 1/4 mile would be a RWD with sticky tires
Cheers,
Dave
Old May 8, 2018 | 01:38 PM
mj1903's Avatar
Default :)
All stock. FK510 tires.
Old May 8, 2018 | 01:43 PM
mj1903's Avatar
My times have all been extremely consistent. Here is my highest MPH from that night.
Old May 8, 2018 | 01:45 PM
Gibbo205's Avatar
Video of my run:
Old May 8, 2018 | 01:50 PM
mj1903's Avatar
I'd like to see what a stage 1 and then with a pulley upgrade, tuned v8 with intake would run consistently. See if it's really worth the money and not just that addicting supercharger whine. lol
Old May 8, 2018 | 02:44 PM
Stohlen's Avatar
For me it was worth two tenths of a second to date. I started running into wheel spin issues along with fuel dump to cool the cats at high RPM. I’m planning to give the strip another shot after the PS4S tires go on this week and that should give a good idea of the real gains from a lower pulley/tune/colder plugs.
Old May 8, 2018 | 02:47 PM
mj1903's Avatar
What is your best time and mph so far?
Old May 8, 2018 | 05:56 PM
Stohlen's Avatar
11.39 @ 123. Both a little disappointing, but when reviewing the logs; its quite clear the vehicle just falls off at the top end because of fuel dump. I didn't let it cool enough between runs.
Old May 8, 2018 | 07:05 PM
SVR's Avatar
SVR
What are you using to log? Wouldn't hurt to add a gallon or two of E85 for its cooling properties and see the results. Most modern performance cars respond really well to lower mixtures of ethanol (~E25-30) over standard E10 pump gas with everything else unchanged.
Old May 8, 2018 | 09:03 PM
Stohlen's Avatar
Its my understanding that the need to dump fuel is based on a calculated value and not actual measured temperatures of the cats. Thus the E85 blend wouldn't help this issue.
I had been using ScanXL to log, but its sampling rate isn't fast enough so i'm looking for something else.
Old May 13, 2018 | 01:50 AM
mj1903's Avatar
I tried 100 octane to see if that would make a difference in my times and to see if I might be pulling timing, I saw ZERO improvement for the stock tune on 100 vs 93.
Old May 13, 2018 | 09:53 AM
Chawumba's Avatar
Not surprised no gains beyond 93 octane, but be glad you have it. Here in Cali we get crap 91 octane...
LynxFX
May 6, 2015 06:50 AM
Gene T
Apr 13, 2015 08:42 AM
Justink201
Jun 13, 2014 07:01 AM
Cambo
Europe
Apr 24, 2013 02:37 PM
royeco
Mar 12, 2010 11:05 AM
