Has anyone here changed a convertible module on their F type? My Roof stopped working a month ago, I think I got some water in the left side Module. Have diagnose the system and electrical components to the best of my abilities and even changed the module for a used one which seem to work for a day but went back to not functioning. Anyone has done this here in the forum? Help is much appreciated, thanks.
I have similar problem no communication w control module
can you tell me where it is located??
thx!!
Officially fixed the car couple weeks ago. If anyone runs into this problem and would like some help reach out. I read on different forums that some dealers won't work on the top and some just want to replace the whole assembly instead of fixing the actual problem $$.
so scanned shows no communication w power top module
does anyone know the location.
was able to buy the module on Ebay
thx
This workshop manual has quite a bit of info on the folding top, including on how to manually lower it in addition to manually closing it, and how to access various components. https://www.dropbox.com/scl/fi/o6d1x...k7yc02pyx&dl=0
Hi all - same problem on my I think…roof stuck closed, probably need to access the rear control module. Anyone work out the mysterious rear motor access technique, or which page of the manual shows how to get the roof retracted manually?! :-)
I'm in need of help! The side panels will not go down...although the top cycles correctly. I'm thinking its a position sensor, but having trouble locating them...and don't know what to do after I do located them, 'maybe replace them?" Any help is greatly apprecciated! Thank you for your post. It seems to be the only one on the internet.
After figuring out which module is compromised based on OBD2 data, rather than cutting a square out of the rear wheel well liner, one could jack the car up, remove the wheel and liner, and get direct access to the critical components.
Another excellent thread from 2018 with some nice diagrams and pictures:
Removal of the hex bolt and receiver nut from both sides enables manual opening as well as closing (see comments). Here are some stills, hole is just left of the finger.
Two-person job to remove, 2 bolts from each side to the body?
