58mm Upper pulley installed on V6 XF-S
Old Aug 11, 2020 | 05:21 PM
Motorcity XF's Avatar
Default 58mm Upper pulley installed on V6 XF-S
After waiting over a month for the US postal service to deliver my pulley I finally installed it.
First things first..... NO MORE CUTTING OR GRINDING UPPER PULLEYS OFF!
Also the was no grinding needed on the snout to fit.
I had an hour of time put into the removal and install from start to finish.
There is a little more low end torque which I was hoping for but Im going to need to ditch the Racechip and get VAP to tune for the pulley.
I made a quick youtube video showing the removal. Excuse my elbows,they're a little ashy. LOL
Old Aug 12, 2020 | 09:33 AM
madmax1911's Avatar
Very nice puller, where did you buy it?.
The right tool for the right job always makes life easier.
Old Aug 12, 2020 | 10:42 AM
Tel's Avatar
Tel
They are a nicely made tool however, there is just not enough room to weild one on the F-Type.
I tried the forge puller but had to send it back as there is little to no room left to play like there is on the XF unfortunately.
Ended up with :
https://altaperformance.com/i-140071...oval-tool.html
and a low profile bolt puller that screws directly into the faces.
This solution was just about low enough profile to have room to get a ratchet/socket combo on.
Old Aug 12, 2020 | 11:24 AM
clubairth1's Avatar
Community Influencer
Nice puller tool!
I have not seen that style before and it seemed to work great for you.
How much was it?
Old Aug 12, 2020 | 12:30 PM
Uro tuning.
Its designed for an Audi S4.
Old Aug 12, 2020 | 12:32 PM
Ended up with :
I first purchased that puller but didnt have confidence in the puller.
Old Aug 12, 2020 | 12:33 PM
Nice puller tool!
How much was it?
$157.
I'm willing to rent this 1 out since it will be sitting.
Motorcity XF
XF (X260)
Oct 16, 2020 09:40 AM
Terrance39
Nov 26, 2019 10:56 AM
greenestate
Sep 2, 2019 05:04 AM
FrickenJag
Feb 20, 2018 12:25 PM
Jagman28
Sep 18, 2017 02:42 PM
