Aluminum Cooling Pipes - Finally!!
Old Jun 18, 2024 | 08:10 PM
  #541
dangoesfast's Avatar
Originally Posted by Jagknight85
Yes I would be down to help you out.. I need to see your current set up of pipes. And I can out together a list of tools. ⚒️
Did this argument go on so long that George's mechanic joined the forum? 😂 Or have you also done the replacement without removing the supercharger?
I sort-of know the process for doing it the regular way (as much as I can from reading the manuals but not having done it yet), but I'm interested in trying George's mechanic's method that doesn't require the s/c to be pulled. I can pull the s/c and I want to do the oil as well but I just thought I might be able to settle this f'ing argument once and for all by doing it that way 😂 😂
Old Jun 19, 2024 | 03:53 AM
  #542
GeorgeIII's Avatar
Originally Posted by dangoesfast
Did this argument go on so long that George's mechanic joined the forum? 😂 Or have you also done the replacement without removing the supercharger?😂 😂
Jagnight85 is my mechanic and he did join this forum specifically to address his procedure in removing the pipes . Actually, he has been great about the whole thing although he is much more direct about all the flack we having been getting and says I am way to nice and , well, he is much more direct with loads of expletives combined.
I am trying, as his agent, to get a 25% commission but he is balking at that and sticking to .05% . As you can see we are miles apart and I am pretty certain I am not going to see anything close to 25%. But at least we have a good laugh.
Anywy, I am sure that he will help you. He has done well over 40 procedures on JLR vehicles many of folks that I know and he has never had any issues. Send him a PM or a note here and don't forget to remind him of my 25%......
Old Jun 19, 2024 | 04:51 AM
  #543
Awesome! I do want to replace my S/C oil as well and was getting ready to pull the blower, but I'll confirm the location of my bleed port first... if I can get a tube in there, I'll suck it out with a syringe rather than pull the whole thing. I'm about 75% confident in removing and reinstalling the s/c, which isn't really really high enough and is a big part of why I haven't done it yet.. the consequence of me making a mistake is pretty high, so I think I'd rather try to do both jobs without removing it.
@Jagknight85 I'll shoot you a PM
Old Jun 19, 2024 | 09:58 AM
  #544
bfrank1972's Avatar
Just to level set, don't think there was actually much continued debate/drama to worr about here quick recap:
1) $3000 for a full supercharger and pipe replacement is par for the course by a dealer
2) should be half that or a little less by a decent independent mechanic
3) there is a clever way that George's mechanic discovered to remove the lower y pipe without removing the SC, super handy for folks who just want to address that (must have the right tool combo apparently)
4) some folks, like myself, will probably end up removing the supercharger anyways, to address other things under or behind the SC there that may need it. Did not mean to say "shortcut" with a negative connotation mine is a 2015 R with minor water ingress issues for instance, so I'd like to see what's happening under there, easier to do a total coolant hose/pipe/manifold overhaul, do a bit of sc maint while I'm in there etc. So I'm in for the spend (or DIY time if I have it) regardless.
Cheers,
Brad
Old Jun 19, 2024 | 10:25 AM
  #545
jahummer's Avatar
I certainly hope this doesn't come off as an argument. I appreciate @Jagknight85 and @GeorgeIII offering an explanation for an alternative method and I appreciate the fact a franchised main dealer's offering massive discounts on standard book time by reducing the hours and costs for service as well as allowing customer supplied parts. Main dealers here offer neither.
I've simply been attempting to replicate the steps stated and demonstrated here so I can figure out how to do it via this shortcut method. Since it only takes me roughly 30 minutes to remove the supercharger, I was simply curious. It's not complicated and the only hurdle encountered with the shortcut so far is finding a torx bit which'll fit the tiny gap and long enough to reach between the y-pipe and supercharger snout and under it. One of the videos the tech posted shows a 6-inch T30 bit but I used an 8-inch T30 and it still wouldn't reach. In the original video the tech shows using what appears to be a long 1/4" socket extension (screenshot below) but that certainly doesn't fit on mine as it's larger than a T30 bit, I have 1" all the way up to 24" 1/4" extensions and socket bits and u-joints.
Member @clubairth1 suggested a 12" T30 screwdriver and when I get around to buying one, I'll give it a try. Gearwrench offer 18" torx, but T25's the largest size...
Old Jun 19, 2024 | 10:54 AM
  #546
Originally Posted by jahummer
I certainly hope this doesn't come off as an argument..
I thought my liberal use of emojis and forum smilies was enough to convey that I was poking fun... just found it funny that one of the first threads in the "new threads" page when I first clocked back on yesterday after three months off was this one and it doesn't seem to have progressed very far 😂
@bfrank1972 fyi my indy quoted AU$1900 to fit the full Euroamp kit and I'm guessing you're talking USD, so your estimate of "about half of 3k" is pretty spot on
Old Jun 19, 2024 | 11:38 PM
  #547
I've done a pre-inspection and I'm fairly confident I know where everything is, so I think I'd like to go ahead with replacing the water pump and two primary cooling pipes fairly quickly (maybe this weekend?) as I'm pretty nervous about one of those exploding any day now. I think I'll do the coupler separately, so the snout will stay on for my attempt. There's a bunch of other small parts in the Euroamp kit that I don't know when I'll install, but I'll feel better knowing that the two big pipes are done.
Before I got distracted from the forums a few months ago there was some talk of the Euroamp o-rings failing and suggestions to replace them with high quality high-temp ones. Any development on that?
P.S....
IF you know of something 15 inches or longer, point me in that direction, it might help.
I knew a bloke in high school that would swear blind he could help you out with this......
Sorry I was catching up on what I've missed over the past couple of months and couldn't help myself
Old Jun 20, 2024 | 01:56 PM
  #548
waldo's Avatar
...Before I got distracted from the forums a few months ago there was some talk of the Euroamp o-rings failing and suggestions to replace them with high quality high-temp ones. Any development on that?...
I just purchased a set of EuroAmp aluminum cooling pipes and plan to install them in my F-Type in a few weeks. After reading about the o-ring issues, I ordered and plan to use factory o-rings (part # AJ811350) when I install the aluminum pipes. I'll let you know how the factory o-rings compare to the the EuroAmp o-rings.
Old Jun 20, 2024 | 04:56 PM
  #549
Awesome, thank you very much for the part number. Think I'll order today.
Old Jul 12, 2024 | 03:53 PM
  #550
waldo's Avatar
The EuroAmp supplied o-ring is on the right. The OEM Jaguar o-ring (#AJ811350) is on the left. The EuroAmp o-ring is slightly thicker. The OEM Jaguar o-rings don’t quite fill the o-ring slots on the aluminum EuroAmp lower coolant pipe, but you can feel them seal when inserting the lower pipe into the block.
Old Jul 19, 2024 | 11:33 AM
  #551
Nmg3693's Avatar
lol My god she will kill you. HAha I was thinking oh, He must live alone. Pray that your wife never sees this. I love my car, But I would murder my husband if he did this. I would also never let him under the hood. He couldn't change a tire , let alone fine clean gaskets and heads. They do look great though!
Old Jul 23, 2024 | 06:32 PM
  #552
Luc Lapierre's Avatar
Default Finally :D
Old Jul 23, 2024 | 10:49 PM
  #553
dennis black's Avatar
20 Year Member
Like I said in my Videos ,use the oem O,rings and you'll be fine
Old Jul 23, 2024 | 10:56 PM
  #554
Thanks Dennis,
yes I did let them know ahead of time about the o-rings (which I learned about from your videos, thank you); turns out they already knew about it.
Maybe they're subscribers
Old Jul 24, 2024 | 07:50 AM
  #555
20 Year Member
Yes ,on the last F-type I installed the metal cooling setup and the solid coupler, he drove to Florida from New York, around 3000miles and had no issues, temperatures up there were in the 95s plus, and he had a blast ,a good feeling that you can take a trip worry free
Old Jul 30, 2024 | 06:46 PM
  #556
I just completed a 1000-km roadtrip full of challenging mountain twisties and high-speed sweepers.
The EuroAMP kit performed perfectly - the car didn't lose a single drop of coolant!
PS if anyone is looking for the perfect F-Type road, I might suggest the Crow's Nest Highway: BC HWY3 between Princeton and Hope, specifically near Copper Mountain. Saw plenty of GT3s, Corvettes, etc up there having a blast. Just time it to avoid trucks and RVs.
Old Aug 18, 2024 | 01:24 PM
  #557
jahummer's Avatar
I would buy those cheap 12" long Torx screw drivers I posted above and then cut off the screw driver handle off and weld a cheap HF 1/4" adapter on it? Heck you could just grind the end of the steel rod square and put a vice-grip on it?
The set of 6 is only $22.
So I did manage to find a VERY long (15" ?) thin T30 and have a few other options as well.
I'm going to be replacing ALL of the hoses, (upper, lower, heater, transmission, radiator, intercooler, thermostat, etc) again in the next few weeks and I will again attempt @Jagknight85 's alternative method for removing the RH pipe screw.
Old Aug 18, 2024 | 03:20 PM
  #558
clubairth1's Avatar
Community Influencer
Well don't keep us in suspense?
A link for the long T30? Heck I could only find that 12" one.
When you figure this out I may give it a go too?
Old Oct 21, 2024 | 12:09 PM
  #559
silvertonesx24's Avatar
How did this method turn out?
My x351 has the aluminum pipe from factory, but I want to do this on my Range Rover soon
Old Oct 21, 2024 | 12:37 PM
  #560
sov211's Avatar
Originally Posted by Luc Lapierre
Is anyone else having trouble finding someone who's willing to do this?
You'd think I was asking them to turn lead into gold... I just want a few pipes replaced...
Luc, you might want to come to Victoria…the JLR dealer here has no issues about doing this work.
