Aluminum Cooling Pipes - Finally!!
Old Feb 6, 2025 | 04:28 AM
  #581
jahummer's Avatar
Originally Posted by J444G
Would this be the right shopping cart for the job if I want to go OEM? I the pipes are these "new" jaguar aluminium ones, but I am not sure if anybody actually put them into V6 F-type yet...
The 3 pipes you’ve listed are plastic as that’s all JLR offer. I’d highly advise replacing with aluminum as discussed in this thread unless you intended to do this full service every 40-50K miles.
Old Feb 6, 2025 | 05:02 AM
  #582
J444G's Avatar
They are not, only the oil pipe. The remaining two are Jaguar Aluminium. Check the part no.
However, I did not find anybody here who would use them yet on a V6. But the plastic ones are the same for V6 and V8, so I hope these will fit. There were fit to F-paces and land rovers tho...
Old Feb 6, 2025 | 09:15 AM
  #583
jahummer's Avatar
You're right! Apparently these were made by Land Rover exclusively for the 5.0 litre V8 Defenders. Good find!
EDIT: Hmmm, I've got the cheap knockoff pipes, no issues but seriously tempted to order these whilst the engine's still torn down...
Old Feb 6, 2025 | 09:48 AM
  #584
clubairth1's Avatar
Community Influencer
Yea it's still a big mystery why?
Jaguar started out with Aluminum cooling pipes when the 5.0L came out then 2 years later they released them in plastic and then all the fun started. Although to be fair the first Aluminum pipes did have a failure prone plastic connector between them.
But in 2024 or 2025 JLR has again went back to the Aluminum versions BUT only released with LR part numbers. Almost all parts will usually have a separate LR and a Jaguar part number.
Glad to hear they did release them but still interested in what caused them to do this. Of course why did they stop there? We have the thermostat housing and the rear water manifold plus the oil cooler brick transfer tube in Aluminum in the after market. These have all shown to be failure prone as well.
Old Feb 6, 2025 | 09:55 AM
  #585
jahummer's Avatar
Just purchased at the main dealer, in stock. Will post up pics later today.
Glad JLR waited until now to do this just as they've replaced the AJ with the TTV8 from BMW...
Old Feb 6, 2025 | 10:02 AM
  #586
J444G's Avatar
Do you have F-type? What engine if so? I think they should fit V6, as they fit V6 F-pace, and the plastic pipes in the same for V6 and V8... But I don't think anybody used them yet.
Old Feb 6, 2025 | 10:04 AM
  #587
J444G's Avatar
Originally Posted by MaxD
I wonder where mine is...
It looks correct to me. In my opinion, I would use the aluminium version of the C2Z18658 if you're replacing the plastic pipes with aluminium (LR186859 & LR186917) - it's between the arms of the "Y" pipe.
The C2Z18658 is not in metal by OEM, right? Is this part a a significant risk? I don't recall it being a problem here.
Old Feb 6, 2025 | 10:21 AM
  #588
jahummer's Avatar
I've replaced this tube about 6 times, current one's alloy. Never had one fail but done as preventative. Nearly all other plastic cooling circuit bits have crumbled at some point on this SCV6 engine (the pipes everyone speaks of aren't the only parts which fail here). What does leak on this outlet pipe are the o-rings. Since new pipes come with new o-rings, for less than $20 it's best to replace the whole thing.
Old Feb 6, 2025 | 07:49 PM
  #589
Gasman2's Avatar
  1. Replaced mine and have the rear crossover one waiting in the garage
  2. decided the bare alloy is untidy
  3. also converted mine to allow fitment of an6 fittings after the hose to the header tank popped off
  4. ps the silicon was for a headlight on my runaround
Old Feb 7, 2025 | 09:20 AM
  #590
J444G's Avatar
If anyone is interested, Britcar.com asked Jaguar about the OEM aluminum pipes and Jaguar confirmed fitment for V6 F-type, so I have ordered them and let see.
Old Feb 7, 2025 | 09:55 AM
  #591
jahummer's Avatar
Yes they fit. Quite heavy (and very well made) compared to the aftermarket versions. Picked them up yesterday. Main dealer said they were made available November last. Even their service department didn’t know they were available. JLR still
offer the plastic versions at a discount.
Old Feb 7, 2025 | 10:42 AM
  #592
JagCode3's Avatar
@Gasman2 Can you let us know where you got your metal rear pipe?
No JLR option yet I assume for this part?
Speaking of not having to remove the SC to replace the pipes, here is the procedure for the rear!
Old Feb 7, 2025 | 02:57 PM
  #593
Gasman2's Avatar
Got the rear crossover pipe from Ali express
Old Feb 7, 2025 | 05:24 PM
  #594
sov211's Avatar
Better than Ali express is simply buying the metal rear crossover from EuroAmp, which is what I put on my car. Perfect. No issues.
Old Feb 7, 2025 | 07:38 PM
  #595
jahummer's Avatar
Here are the genuine JLR versions
Old Feb 7, 2025 | 09:29 PM
  #596
JagCode3's Avatar
@jahummer Thanks for the pics - I like how the new OEM aluminum pipes have cast logos and actually look good. Now ordering mine from a JLR dealer online. I noticed many "OEM"s on eBay without the cast J and LR logos, part number and QR code. Just the cut out JLR part label placed on top to make it look legit. One did have the cast logos but no part number or QR code.
What was your source for the aluminum C2Z18658?
Old Feb 7, 2025 | 11:44 PM
  #597
Gasman2's Avatar
I do have to chuckle
why would you think a part made in India is superior to a part made in china
Jlr oe stuff is shocking quality
mine is chinese
Old Feb 8, 2025 | 07:25 AM
  #598
jahummer's Avatar
mine is chinese
I hope this wasn’t a serious question. The country of manufacture has absolutely NOTHING to do with the quality of the part.
Genuine parts HAVE to meet certain standards of quality (and regulation) AND fitment. Aftermarket (in most instances) and KO parts aren’t required to and are often inferior.
Old Feb 8, 2025 | 08:12 AM
  #599
Gasman2's Avatar
Omg you actually believe jaguar parts are high quality
cheap tata steel
misaligned panels
brittle plastic clips everywhere
brakes that they got from the parts bin
I love my car but it’s a poor man’s supercar
Old Feb 8, 2025 | 08:49 AM
  #600
jahummer's Avatar
That is a correct statement. Jag’s are economy cars. They’re not super cars and were never intended to be….
I’ve been repairing and building cars of many marques from Asia, Europe and USA for over 20 years. I speak from knowledge and experience. JLR vehicles have been some of the easiest and most reliable in their class to work on and own.
