Annoying Horn Sound Help
Old Jul 11, 2022 | 03:13 PM
newskatercat's Avatar
Veteran: Marine Corp
Question Annoying Horn Sound Help
Not the actual horn from the steering wheel. Very often wiping car down with car unlocked, door handle sticking out, I will brush against the door handle, and get this embarrassing meep meep! Sounds like something that belongs in a much lesser car! What is the actual purpose of this mini horn? Anyone know where it's located, and how to disable it? Thanks!
Old Jul 11, 2022 | 03:20 PM
Dogbreath!'s Avatar
It lets you know that the car didn't lock because something is open.
Old Jul 11, 2022 | 04:17 PM
Slochap's Avatar
You can unplug the extra horn under the cabin air filter area.
Old Jul 11, 2022 | 04:38 PM
Thunder Dump's Avatar
This can happen when water is present on the surface and you have the keyfob in your pocket. Don't wash the car with the keyfob on you (either leave it in the car or well away from the car) and this problem will go away.
Old Jul 11, 2022 | 04:46 PM
Actually when I don't have the key on me, it beeps every time, wet or not! With key it locks!
Old Jul 11, 2022 | 05:10 PM
My bad....that's correct behavior. It'll beep twice and won't lock if you don't have the key on you. So wash the car *with* the key on you and that should stop.
Old Jul 11, 2022 | 05:26 PM
uncheel's Avatar
That's what you should see. As mentioned above, you get the beep because the car is "warning" you that you're (apparently) trying to lock the car by pushing in the door handle in when something is ajar - like the door is open. If you close the door and lock the car, all will be well (and quiet).
You'll also (and probably more commonly) get the beep it if a passenger or bystander puts pressure on the door handle when you're not around with the fob. I'd keep the beep-beep going just for the bystander part.
One other thing you might run across as a surprise. If you unlock the car, but don't actually open the door to get in ('cause you're just washing the car), after a minute or so, the car will re-lock itself. (No beep)
Old Jul 11, 2022 | 05:49 PM
Anyone disconnect this horn, and how? Picture would be amazing!
Old Jul 12, 2022 | 09:07 AM
Brit-Type's Avatar
Meep-meep delete:
https://www.jaguarforums.com/forum/f...oblems-189060/
#18 has a good photo.
Not sure if it affects the security alarm. I've never set mine off.
Old Jul 12, 2022 | 11:49 AM
Valerie Stabenow's Avatar
Default Disconnect the warning horn???
I look at this as a security feature and not one to disconnect. It lets you know someone else that possibly should not be around your car is there.
If you do still want to disconnect and have a 2017 or similar model, I can provide updated photos of the horn area, as the method to access is a bit different from that shown in the link provided. MY2017 has more of those little screw down fasteners to the cabin filter access door and then you have to take the cabin filter out to see the horn
Old Jul 12, 2022 | 12:13 PM
CJSJAG's Avatar
I guess we all have our pet peeves!!
This is not one of mine.
Old Jul 12, 2022 | 02:26 PM
Thumbs up
Now knowing the purpose of the horn, and being able to avoid it by having the fob in my pocket, I'm good! Thanks all for the info!
Old Jul 12, 2022 | 10:55 PM
Sparky H's Avatar
Unhngd and The Rock had the BEST option. I did it and it is PERFECT.
I purchased a $3.00 less obnoxious unit from Amazon with a simple splice and plug in. Easily accesible from pasenger side engine bay under the lid closest to windshield. You may find it with a search or pm UNHNGD
Old Jul 12, 2022 | 10:57 PM
Sparky H's Avatar
It now sounds similar to an EXOTIC.
Old Jul 14, 2022 | 12:46 AM
takeapieandrun's Avatar
Check out this brief video I made showing my replacement sound - and also check the below DIY thread.
jag_guy_2020
Jan 1, 2021 08:08 AM
brinny
Dec 31, 2020 06:46 PM
15FTypeR
Dec 1, 2020 11:26 PM
SableCat
Jun 12, 2020 07:09 AM
Ubad2
May 30, 2019 07:18 AM
