Anyone replace front plastic air splitter?
Old Aug 14, 2015 | 09:42 AM
JarodL's Avatar
Default Anyone replace front plastic air splitter?
Barrett sells all three pieces for ~$100 shipped. Curious if this is something that just pops right off, or you need the car on a lift to do it.
Old Aug 14, 2015 | 10:34 AM
shift's Avatar
There's instructions somewhere on the forum....can't find it right now. The side pieces come off with 4 bolts, can be done with lift. I just did it. Very easy. The main front one from what I remember is more involved but still don't think u need a lift. But will make life easier since not much clearance to get wrench going.
Old Aug 14, 2015 | 10:35 AM
shift's Avatar
I meant can be done without lift for sides, and probably without for front.
Old Aug 14, 2015 | 11:46 AM
JarodL's Avatar
Thanks. If anyone has a link to the instructions, it would be much appreciated.
Old Aug 15, 2015 | 09:45 PM
TXJagR's Avatar
Ask and you shall receive!
File Type: pdf
Old Feb 6, 2025 | 09:21 AM
mitchyz250f's Avatar
TXJagR,
How is that pdf so clear? I have the digital manual and everything looks so pixilated? Where are those instruction from?
Old Feb 6, 2025 | 07:26 PM
Valerie Stabenow's Avatar
Default Instructions really not necessary
With good lighting and a piece of cardboard to lie on, you can do this without a lift. The three pieces interlock and they fit under tabs on the car. There are 7 or 8 screws. When reinstalling, connect the pieces to each other, tape them together and then offer up the assembly. I did this by myself, but a helper would make it easier. Get the screws started, make sure the sections stay together. Tighten the screws a little bit as you move along the length of the splitter, making sure the sections fit in the tabs. Continue to tighten each screw in turn, until the splitter is fully seated. Don't be disappointed if one of the section pops out of its tab. Loosen the adjacent screws, use a flat blade screwdriver or plastic trim tool to get it back under the tab. I have the splitter I took off, will get some photos and add them
Old Feb 6, 2025 | 08:51 PM
OzXFR's Avatar
Some confusion here.
This is a damn near 10 year old thread, and it is about replacing the front splitter/diffuser piece not the three bits of plastic trim on the underside of the front under-tray.
How do I know?
Coz I busted that splitter some eight years ago now and bought and fitted a new one!
The splitter/diffuser does not interlock with the under-tray at all, instead it is bolted/screwed to the front bumper cover.
It's just that you need to remove the two outer pieces of plastic (winglets???) to remove the under-tray to then access the splitter.
Wolvesboy
Dec 16, 2023 01:53 AM
LedZepplin
Jun 17, 2017 01:20 PM
Heliwilly
Aug 19, 2015 03:21 PM
Warspite
Apr 7, 2015 07:59 PM
AdrianSw
XJ40 ( XJ81 )
36
Nov 7, 2011 10:02 AM
