Battery Tender - CTEK MUS 4.3?
Old Jan 2, 2018 | 07:57 AM
ek993's Avatar
Default Battery Tender - CTEK MUS 4.3?
Had a low battery warning yesterday - first time I have experienced it with my car, guess the frigid temperatures here in the NE along with minimal driving over the holidays is to blame. Also had a BlackVue with Power Magic Pro installed 6 months ago (set to 12 hours / 12v cut off), so that might also be a contributor?
Anyway... want to get a battery tender, the CTEK MUS 4.3. Saw a thread on here mention the model, is it still the recommended choice?
Old Jan 2, 2018 | 09:07 AM
spanky145's Avatar
The CTEK seems to be the current battery tender of choice. However, when I bought my car and previous BMW the dealers were selling the Battery Tender Plus so I bought one of those and have been using it for the past few years with various cars and with no problems at all. Can't really say which one is better but from personal use and experience the Battery Tender Plus has performed flawlessly. In fact, my dealer has all of his showroom cars connected to a Battery Tender plus.
Old Jan 2, 2018 | 09:46 AM
ek993's Avatar
Is this all I need - or are there additional cables / connectors / harnesses needed as well?
Amazon Amazon
Old Jan 2, 2018 | 09:55 AM
DJS's Avatar
DJS
Looks like it includes two pigtails - one with eyelets, one with battery clamps. Should be all you need.
Old Jan 2, 2018 | 09:56 AM
malbec's Avatar
Get the extension cable as well.
Make easy permanent connector in trunk. Pics on here how to do.
Old Jan 2, 2018 | 10:20 AM
ek993's Avatar
Thanks all, have ordered unit + extended cables
Old Jan 2, 2018 | 02:52 PM
FType17's Avatar
I use several of these on all my cars and I like the ability to avoid installing the pigtails with the included battery charger adapter. The price is great and in years it never let me down http://a.co/1GfAleH
Old Jan 2, 2018 | 08:51 PM
pdupler's Avatar
I've got a couple of classic cars and used Sears Diehard, Battery Tenders, CTEK and even more recently a Battery Minder which was the type recommended by the manufacturer of a 1960s Delco "restoration battery". I would never use a Diehard again. I've had a couple of Battery Tenders fail, but unlike the Sears, at least they fail in the "off" position instead of full "on" like the Sears. Have four CTEK's and a Battery Minder going right now but haven't had them long enough yet to know about long-term reliability.
One thing in your case to make sure of is that no matter which brand you choose, be sure to get one with more amperage capacity than your car draws when off. I learned that the hard way with a vintage Corvette that if I don't get the ignition key in just the right spot when I pull it out, then it can leave the car energized. If the car is drawing more current than the tender can put out, then it will run down the battery, but the tender will still continue charging for all its worth and ultimately damage the battery. The CTEK's 4.3 might be enough, but some of the little 1 or 2 amp units might not be. Modern cars tend to draw a lot of current even with the ignition off plus you're running a dash cam in parking mode.
Old Jan 6, 2018 | 09:58 AM
ek993's Avatar
Installing the CTEK today. First of all managed to crack the plastic lid to the wiring bus - undoing those clips wasn't easy.
Now - I need to undo the nuts to connect the eyelets. What size spanner do I need?
Old Jan 6, 2018 | 03:39 PM
ek993's Avatar
OK, what am I doing wrong... I can't attach the negative eyelet (black cable) to the location shown in the instructional photo. I undid the nut but the eyelet won't fit, it seems to be too small and only goes partially down the threaded metal stud.
I am using the standard "comfort connect" eyelet cable that came in the CTEK box, says it is an M6
Once I remove the nut am I supposed to lift off the thick black cable that is there, attach the CTEK eyelet and then place the thick black cable back on top?
Or.. remove the nut and place the eyelet on top of the existing cable that is there?
Old Jan 6, 2018 | 05:07 PM
jaguny's Avatar
Ek993, when I installed my ctek, I couldnt get the eyelet to fit over the pin. I used a different pin that was further down (using your picture as reference) and to the far right. It stretched the length of the eyelet wire (that I separated further from the positive wire). No issues last winter. Reconnected same way this winter. I will remove both connections and the pigtail and tighten nuts when I take car out in the spring. I had a loose connection contribute to a grounding problem that was resolved when I retightened everything after removing the tender.
Old Jan 6, 2018 | 05:30 PM
ek993's Avatar
Would you be able to take a photo to show where you have connected the eyelets when you get a chance?How about the red eyelet, did you connect to the same place as Foosh’s photo - opposite the yellow wire? I’m having challenges with that one as well - as can be seen from the photo I took the cable is fatter where it connects to the eyelet and won’t sit flush on the wiring bar. Foosh’s cable looks a lot thinner. Do I need to order a different eyelet cable? In the interim I connected the CTEK to the jump points under the hood with the alligator clips so I can get a charge.
Old Jan 7, 2018 | 05:43 AM
jaguny's Avatar
Yes, I connected positive to same place as Foosh opposite the yellow wire. I didn't have an issue there that I recall. I'll see about the photo. Car is in my detached garage, just need to shovel to get in.
Old Jan 7, 2018 | 07:19 PM
uncheel's Avatar
[QUOTE=ek993;1818305]Is this all I need - or are there additional cables / connectors / harnesses needed as well?
If you have another vehicle, consider getting an extra piglet. I have one permanently wired into the F-Type, and another on my lawn tractor (there's a pair for you). I've had the side benefit that my lawn tractor battery has lasted far longer than usual.
mij86
Jan 13, 2018 12:11 PM
jaguny
Dec 22, 2016 04:59 PM
06-XJR
16
Jul 5, 2016 11:13 AM
hawaii
Aug 9, 2014 10:49 PM
fabfive
May 6, 2014 03:19 PM
