Bye bye v6
Old May 5, 2015 | 11:58 PM
bjg625's Avatar
Question Bye bye v6
Just read on CARBUZZ that after '16 Jag is replacing 3.0 SC V6 with turbocharged straight 6 from newer Jag/LR series engines. Supposedly for world wide fuel economy . Quote"should offer improved smoothness,more power and better efficiency". Ingenium series engine! They quoted Motor Trend.
Old May 6, 2015 | 01:05 AM
shift's Avatar
no surprise. big question mark is how will it sound?
Old May 6, 2015 | 01:28 AM
Cambo's Avatar
Don't post up a link or something....
Jaguar working on straight-six Ingenium engine ? report
Just hope it doesn't sound like a 2JZ...
Old May 6, 2015 | 01:36 AM
PapasC7's Avatar
They have done an amazing job with the F-Type exhaust so far. I am sure they will not let us down... Let's hope anyway....
Old May 6, 2015 | 06:34 AM
mshedden's Avatar
Well, if the sound isn't so great, they can always synthesize the sound and pump it through the Meridian - the rattles, buzzing and crackles will then be a feature.
Old May 6, 2015 | 07:00 AM
Foosh's Avatar
Most likely more like the current M3/M4. The sound wizards will really have to come up with a miracle, but it won't be nearly as exotic sounding.
I realize JLR doesn't have any choice to get to increasingly restrictive worldwide CAFE standards.
Old May 6, 2015 | 07:34 AM
Joz132's Avatar
I hope not - my M4 sounded like a broken lawnmower
Old May 6, 2015 | 08:03 AM
Foosh's Avatar
I know, hence the sad emoticon. Straight six architecture + turbo = exhaust tones that most car nuts find inferior to other choices.
Old May 6, 2015 | 08:15 AM
ShaunPA's Avatar
Im not worried about this at all ... Jaguar seems to be pretty good in the exhaust sound tuning department.
The Range Rover has the same 550hp V8 as the R coupe and that is quiet and smooth as can be, while the R coupe is a snarly, cracking, popping monster.
Old May 6, 2015 | 08:23 AM
duprey26's Avatar
OK, that clarified it for me. I was struggling to understand why an I6 would sound inferior to a V6. After all, JLR acoustic engineers are on the record stating that they worked the F-type exhaust to mimic much of the qualities of the E-type, which was a NA I6 that sounded fantastic. What I was missing in the equation was the turbo. Stripping exhaust to spin the compressor, along with the turbo whine and bleed-off noises is the real problem here, not the architecture (V vs. in-line) of the engine.
Yes, it will probably take some extreme effort to make a turbo engine sound as good as our current SC lineup.
On the plus side, with the inherent smoothness of an I6, JLR could make it a high-revving (8k RPM), high-output engine whose performance might make you forget the lower exhaust sound quality. The induction sound of a smooth spinning high RPM engine could very well balance out or even outweigh the exhaust note at high revs.
Old May 6, 2015 | 08:51 AM
Foosh's Avatar
Agreed, and I'll keep an open mind. A NA straight-six can sound delightfully, rich, and silky smooth. I've got to believe BMW tried to get the twin-turbo, I6 up to enthusiast caliber acoustics, but I think it's a failure in that regard.
However, Jaguar seems to put a higher premium on this dimension and seems to go to greater lengths to achieve it. Nonetheless, engine architecture (cylinder number and layout) always dictates what you can do with the acoustics, and forced air adds another layer of complication. For example, it's very hard to make a V-10 sound pleasing no matter what you do.
Old May 6, 2015 | 09:35 AM
buickfunnycar.com's Avatar
No worries...makes our base '15 Coupes even more rare.
Old May 6, 2015 | 09:53 AM
SoCalJagS's Avatar
Just be glad they are keeping their V8's for now.
Old May 6, 2015 | 02:18 PM
rav1up's Avatar
Exactly my thoughts! The originals will remain wanted.
Old May 6, 2015 | 02:34 PM
Originally Posted by rav1up
Exactly my thoughts! The originals will remain wanted...
Including the US-spec RWD V8's...
Old May 7, 2015 | 10:05 AM
Arne's Avatar
I will try to keep an open mind til I have actually heard it, but it will be very difficult to match the sound of a supercharged or na engine with a turbocharged one. The turbo will muffel the sound no matter what they do otherwise.
Just listen to the F1 after they turbocharged those engines, even though the displacement was drastically reduced as well.
I think this is going to be a very difficult task for the engineers....
Old May 7, 2015 | 01:09 PM
Unhingd's Avatar
I have to think that dropping in an I6 will mess with the fr/rr weight balance the V6 currently has.
Old May 7, 2015 | 01:15 PM
Frankly I think it's crazy...manufactures went away from a straight design for packaging reasons,I cannot see the point in going backwards.
I guess at least with a straight design,there should be more room on the sides to hang the hairdryers...but I don't get that either.
The old saying still somewhat applies here..."Injection is nice but I'd rather be blown".
Old May 7, 2015 | 02:36 PM
F-typical's Avatar
I wonder how well that would fit - at getting on for twice the length quite a few other bits are going to have to be relocated.
The M54 in the shopping car apparently sounds fantastic, but is too quiet to hear while driving...
Roman fellow
Sep 26, 2015 10:19 AM
abonano
25
Sep 25, 2015 10:43 AM
edtexas
Sep 4, 2015 08:20 PM
scardini1
Aug 24, 2015 09:47 AM
ahspros
Jul 14, 2015 09:48 AM
