center wheel cap removal
Old Jul 10, 2020 | 07:59 AM
2004XJ8's Avatar
Default center wheel cap removal
Quick question? Do I meed to remove the wheel to get the center cap off or can it be done with the wheel on the car?
I don't want to just start prying things off?
Old Jul 10, 2020 | 08:53 AM
scm's Avatar
scm
The safest way (assuming you can handle the weight!) is take the wheel off and poke the cap out from the back. Doing it from the front risks damaging it as it's a tight fit.
Old Jul 10, 2020 | 09:02 AM
Wink5's Avatar
I did it about 3 weeks ago, used a plastic spackling knife (covered in painters tape just in case) and they popped right off.
malbec's Avatar
On my old XKR I could pull them off with a suction cup, like you get on a windshield mount. Not tried it on the F.
Old Jul 10, 2020 | 11:15 AM
2004XJ8's Avatar
Thanks Guys!
Old Jul 10, 2020 | 01:45 PM
Unhingd's Avatar
+1. You may need to tap it out with a hammer by inserting the rubber end of a screwdriver into the back of the cap.
Old Jul 12, 2020 | 10:21 PM
domino_z's Avatar
if you're going to discard the wheel caps, i drill a screw into the centre of the cap, then use pliers to pull them off
much easier and quicker than jacking car up, and no risk of chipping wheel finish trying to wedge a tool underneath
works well for the front centre grille badge too
Old Jul 12, 2020 | 10:37 PM
OzXFR's Avatar
Jeez, why would you destroy a full set of OEM centre caps?
Have you seen the price of them?!?
maxiedaniels
May 26, 2020 05:36 PM
Jimmysea
May 19, 2016 06:59 AM
Hafrod
Feb 11, 2016 11:42 PM
Redeye
Aug 25, 2012 06:21 AM
Adam Lueb
Apr 3, 2012 05:41 AM
