Ceramic brakes- Squeaking Noise
Old Jun 10, 2019 | 08:09 AM
mv007F's Avatar
Default Ceramic brakes- Squeaking Noise
Hi Guys ,
Got 12K miles on my Ftype 400 with ceramic brakes and lately the squeaking noice has been unbearable!!
Anybody here that similar experience? Or any advice here before I call service department ?
thanks
Old Jun 10, 2019 | 08:54 AM
vika01's Avatar
This is the problem with ceramic brakes. They do that. If yours is doing it way too much then I don’t know but a simple way to try solving it is hammering the brakes a few times.
Old Jun 10, 2019 | 09:39 AM
mlebofsky's Avatar
YES. And clean/hose them off real well (assuming they are not piping hot)
Old Jun 10, 2019 | 01:03 PM
usgpru27's Avatar
Mine started at 16K. If I wash the car they are good for some time. I also give the brakes a good rip once in a while. It will go away.
Old Jun 10, 2019 | 04:06 PM
scm's Avatar
scm
A bit of noise is a small price to pay for no dust!
Old Jun 10, 2019 | 04:10 PM
Holy F type's Avatar
don't hammer your brakes.. if you chip the rotors then say goodbye to 10k
edit: i thought he meant hammering with an actual hammer
Old Jun 10, 2019 | 04:56 PM
Carbuff2's Avatar
LOL, what do you think @usgpru27 meant when he said to 'rip' them once in a while???
Old Jun 10, 2019 | 05:17 PM
vika01's Avatar
Haha I guess it could be read like that too.
Old Jun 11, 2019 | 06:01 AM
bb_sam's Avatar
Originally Posted by mv007F
Hi Guys ,
thanks
Had the same issue -- check out this thread:
https://www.jaguarforums.com/forum/f...-miles-157813/
There's a TSB on this issue.
https://jlr.oemdtc.com/TSB/SB-10065182-6903.pdf
Old Jun 11, 2019 | 06:23 AM
OzXFR's Avatar
Do you have the CCM brakes?
Also that TSB makes no sense at all, it first of all says "Squeal noise from rear brakes - 380mm brake discs" when the rear "super performance" (iron) brakes are 376 mm not 380 mm (the front "super performance" and "high performance" brake discs are 380 mm) while the rear CCM brake discs are 395 mm (IIRC), then it says "with: high performance brakes" when the rear "high performance" brakes are 326 mm.
In summary that TSB not only has nothing to do with CCM brakes it is a complete dog's breakfast!
Old Jun 11, 2019 | 07:57 AM
Unhingd's Avatar
It probably doesn't matter what that TSB actually applies to. Those are the same steps one would use to resolve the squeaking brake issue on any car.
Old Jun 11, 2019 | 11:27 AM
bb_sam's Avatar
+1
vabeach
Jun 14, 2018 05:20 PM
IMMD
Aug 28, 2017 05:35 AM
pdog2000
Mar 13, 2011 04:39 PM
Lisha
Sights N Sounds
Jan 14, 2009 12:35 AM
