Check engine light question-just popped on
Old Nov 1, 2022 | 09:46 PM
Whatsnext's Avatar
Default Check engine light question-just popped on
My engine light just popped on during my last couple miles to my house. I just had the car in to replace the overflow reservoir tank but I checked that and it is full. I also literally just changed the oil 2 weeks ago and checked the oil again last weekend and it was at full. I have a 2016 R with only 17k. She is rarely driven and trying to think logically what could be wrong. The car seemed to run perfectly normal as well. Any ideas? O2 sensor?
Old Nov 1, 2022 | 10:05 PM
OzXFR's Avatar
Get yourself a decent OBD2 code reader and that should tell you why the CEL has come on, and then you can go from there.
A code reader is an essential tool these days and it can save you thousands chasing gremlins and paying through the nose for dealership diagnostics.
I have used an iCarsoft LR V2.0 for a few years now (a version 3.0 has been out for a while) and it has saved me heaps.
Old Nov 2, 2022 | 12:19 AM
sov211's Avatar
And if it turns out to be an 02 sensor (not uncommon) note that there is an extended Jaguar warranty on these sensors.
Old Nov 2, 2022 | 05:08 AM
scm's Avatar
scm
Sounds like the car is throwing a strop because you don't drive it enough! They don't like being ignored, you know ...
Old Nov 2, 2022 | 06:23 AM
Whatsnext's Avatar
Agreed! She needs to be driven more.
Old Nov 2, 2022 | 06:25 AM
Whatsnext's Avatar
I imagine since I have coolant, oil and she seems to be running fine it should be ok to drive it to the dealer? I have a warranty for another 2 years on the car so if it appears to be "safe to drive" I will just let the dealer deal with it.
Old Nov 2, 2022 | 06:43 AM
OzXFR's Avatar
If it's a solid CEL then no problem driving the car as that means it's just an emissions system issue but if it's a flashing CEL that's much more serious and you should not drive the car.
Old Nov 2, 2022 | 06:45 AM
DJS's Avatar
DJS
You could also drop by Autozone. They’ll read the code for free, I did this once with my XE.
Old Nov 2, 2022 | 06:47 AM
Whatsnext's Avatar
Thank you. That is the info I needed. It is a solid light. I was hoping it was safe to drive and wondering if there is a way to tell since it seems to run just fine.
Old Nov 2, 2022 | 12:34 PM
sov211's Avatar
Your car is safe to drive, and the likely fault is an 02 sensor or possible, but less likely, a fuel injector. But before you go further, the CEL can be triggered by the fuel cap not being properly fitted/ tightened to at least 3 clicks.
Old Nov 2, 2022 | 01:56 PM
Craaaazzy's Avatar
if the issue is the O2 sensor, yes, it would be covered under warranty and would be free to you...BUT I would think that if they replaced the O2, they would also upload the latest software update which could potentially reduce exhaust noise. if this was the issue for me, I think I would just replace the 02 sensors myself...I don't believe they are that expensive (unless u have to replace all 6 of them).
Old Nov 4, 2022 | 03:28 PM
Whatsnext's Avatar
I had it scanned and it is an O2 sensor in bank 2, sensor 3. So from what I can tell that is the drivers side and the furthest back from the motor-correct? Are these accessible with just a jack and creeper? I am not sure how far back that sensor really is in relation to the car. For example near the center of the door or more closer to the rear tire
Old Nov 4, 2022 | 04:28 PM
RGPV6S's Avatar
It is about in the middle of the car and the sensor itself is readily accessible. The plug is a bit hard to get to though. There is a thread with a photo somewhere I will post once I find it.
Picture in post #7:
https://www.jaguarforums.com/forum/f...cation-200433/
Old Nov 4, 2022 | 04:52 PM
NBCat's Avatar
If possible, obtain and post the DTC(s) stored so the reason for the MIL being on is known and diagnosis can be suggested.
If the downstream oxygen sensor on Bank2 is faulty, take the vehicle to a Jaguar main dealer and have it replaced under the emission warranty.
Old Nov 5, 2022 | 03:21 PM
Whatsnext's Avatar
It shows "signal stuck"
Old Nov 5, 2022 | 04:22 PM
NBCat's Avatar
@Whatsnext, use a different reader or a smart phone with the Torque app to connect to the vehicle's PCM via the OBD port with a Bluetooth interface to read DTCs.
Jaguar1611
Jun 21, 2022 04:50 PM
JaggyV6
Jun 20, 2022 04:40 PM
mingstudios
Dec 13, 2017 12:19 PM
ek993
Oct 24, 2014 07:34 AM
IrishXtype
Nov 25, 2009 12:12 PM
