Coupe vs Convertible headroom
Hi all,
I'm looking to get the F type Coupe v6.
The problem is that I'm quite big (in both directions xD )
I tried sitting in the convertible version (since it is the only one they have in my country) and while I have no problem with the width and actually feel quite comfortable my head is almost scraping the roof (like an inch away) even after adjusting the seat.
I'm guessing the Coupe has more headroom, am I right?
Also I am planning on putting the panoramic roof, does that influence headroom in any way? ( I think I read about it somewhere).
And finally, the normal sport seats offer more room than the performance seats, right?
Thank you all in advance and sorry if it was discussed before, I couldn't find exactly what I was looking for
I don't think there's any difference in headroom between the two, having sat in both. Moreover, if you go to the picture (sticky) thread at the top of the forum, you can likely find pictures of both side-by-side. They're the same height in the photos I've seen, and according to my recollection of coupes and convertibles sitting side-by-side on dealer lots.
Did you lower the seat all the way to the floor? I'm 6'2" and have several inches of clearance with my seat all the way down.
P.S. The std sports seats are more accommodating and comfortable, in my view, for larger people. I found the performance seats annoying around my shoulder area.
I am 6'2" as well and I can fit comfortably in the convertible with performance seats however it is pretty much set at the limits of the seat adjustment. You also do find the rear view mirror obscures the front visibility a bit.
6-1 adequate headroom in both The ragtop has great headroom when the top is down- though. I think there was more room in the ragtop as the panorama has some thickness. The first 2 days with the coupe I smacked my head pretty hard getting out - learned behavior no longer an issue though I warn my passengers.
Haha, just hung by the neck , maybe it made it longer which is causing the problem.
I am also 6 foot 2. Thing is I only had a chance to try adjusting the seat for a couple of minutes since it was at a promotional event. I will try to find a dealer with a Coupe somewhere reasonably close to me and then fiddle with the seat for a bit longer.
Do you taller people also recline the seat a bit backwards or is just adjusting the height of it enough?
Once again, thank you all for your fast and helpful answers.
There's not a lot of recline in either coupe or convertible since the rear bulkhead is only a couple of inches behind the seat adjusted all the way back. I do recline it as much as possible, which still leaves me fairly upright with plenty of headroom. I'm actually a click or two forward from the rearward position at 6'2," which give me a little more recline.
The seat does adjust down very low, and that's the main thing you should check. It's actually one of the more comfortable driving positions in any car I've owned.
Bottom line is you shouldn't have a complaint in the world [re] seating.
Good luck.
RJ52
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
Sep 7, 2015 04:28 AM
