Dashcam install Which Fuse
Old Apr 18, 2026 | 01:07 PM
Joons's Avatar
Default Dashcam install Which Fuse
I'm installing a Viofo A229 dash cam, which fuses or fuse locations in the passenger side footwell fuse box should I use so that the camera switches on/off with the ignition, so an ACC (power when ignition on) and B+ (always power)?
Old Apr 18, 2026 | 04:05 PM
Junior150's Avatar
I am just getting power from 12v cigar socket with USB adapter. Doesn't this work in your car?
Old Apr 18, 2026 | 04:17 PM
Joons's Avatar
Yes it does but I want a seamless installation without wires running everywhere. I have this in both my Porsches and it's only a matter of tapping into the right fuse locations and running the wires under the headlining, A pillars etc. Not difficult except for knowing where to plug into.
Old Apr 18, 2026 | 05:02 PM
2018XF25T's Avatar
This wil help you find which fuses powers off when ignition is off and find constant live fuses. The tool is called "car circuit tester". Very easy. And you need a piggy back fuse tap. It should be included with hard wire kit.
Old Apr 18, 2026 | 06:55 PM
RoverJoe's Avatar
Community Influencer
If I had to pick I would choose one of these fuses, either in the left A pillar box or the one under the passenger foot rest area, whatever's easier for you. The fuses shown are for the folding top system, which are not disrupted by any of the quiescent current relays and the circuits should be there on a coupe anyway, maybe without a fuse in them. I would test them for power and just verify they do get juice all the time, but that's where I'd start.
Old Apr 18, 2026 | 07:42 PM
crowsash's Avatar
If you check the "Dashcam Hardwire" thread it might be helpful.
Old Apr 18, 2026 | 07:45 PM
crowsash's Avatar
https://www.jaguarforums.com/forum/f...shcam+hardwire
Old Apr 19, 2026 | 08:30 AM
Joons's Avatar
Perfect, thanks
JDog
Jul 22, 2025 01:50 PM
Rich Tea
Aug 27, 2019 03:57 AM
graham11
Dec 3, 2017 11:46 AM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
Sovereign_ty
XJ40 ( XJ81 )
Dec 30, 2007 06:40 PM
