Disconnected battery, locked trunk convertible
Old 03-14-2023, 12:25 PM
bigbadorange's Avatar
Default Disconnected battery, locked trunk convertible
F-type SVR vert was dead. Popped hood and put on charger, nothing would work and battery appears not to be taking a charge. . (luckily car doors were not locked, it appears niether of my fob keys work in the door lock, anyone else find this?). Was recently OBDII tested for smog, so figured that was the issue. Put jump box on terminals just to get enough power to open trunk and it worked. Seems the recommondation here is to disconnect battery and charge, which I did. Went to check this morning and trunk somehow closed. I had a towel keeping it open, but I guess towel was not thick enough. Now even with jumpbox, I can't get trunk open. When connecting jumpbox, I get about 3 seconds of what seems like the doors trying to index, but then nothing. I reset about 5 times and the same thing. Had my daughter pressing the trunk button on the dash the moment I hooked up the jumpbox and it will not active the trunk. Any ideas on what to do next to get the trunk open so I can get to the battery and test/reconnect?
Old 03-14-2023, 12:52 PM
djyankees31's Avatar
Sorry to hear. I don't have any other advice, except the trunk might be stuck because of the towel is wedged in the lock too. So, it might take a harder lift while trying to open.
Old 03-14-2023, 01:25 PM
DJS's Avatar
DJS
DJS is offline
Received 2,087 Likes on 1,389 Posts
Do you have jumper cables? Maybe jump to another car. I’m sure you’ve tried charging your jump box.
Carbuff2 (03-14-2023)
Old 03-14-2023, 01:45 PM
Ok, thank goodness for another thread I found here, the issue was Apparently BOTH my charger AND my jumpbox are "smart". The little SOBs, sense no battery (since it was disconnected) and turned them selves off after a couple seconds.. I used jumper cables to an actual 12 volt battery and everything lit up and I could open trunk.
The following 2 users liked this post by bigbadorange:
Carbuff2 (03-14-2023), eeeeek (03-14-2023)
Old 03-14-2023, 01:53 PM
eeeeek's Avatar
I read these threads and file the away for later knowledge. That has saved me more than once. Thank you for posting the issue and the resolution.
Old 03-14-2023, 03:08 PM
DJS's Avatar
DJS
DJS is offline
Interesting - so the jump box won’t work with a 100% dead battery.
Jagicon
07-06-2022 03:51 PM
Xeno
16
09-03-2021 08:38 PM
bobhoff
09-29-2018 08:14 AM
slidefighter
04-29-2018 07:14 PM
machi477
72
12-16-2012 08:33 AM
Quick Reply: Disconnected battery, locked trunk convertible
