Do you add fuel/oil addititives?
Old Dec 14, 2019 | 11:06 PM
Holy F type's Avatar
Default Do you add fuel/oil addititives?
Do you add any fuel/oil additives? If so which additives do you use, what are the benefits?
Been reading into these oils and i'm curious what they do for our cars.
Old Dec 15, 2019 | 10:46 AM
FType17's Avatar
No oil additives - NOT GOOD and not needed
Every 3000-5000 miles Redline S1 in the fuel. It works WELL. I checked with an endo camera before and after a tankful with it. Piston heads look like new after. While speculative, I see a 4-5hp at the wheel gain after a tank. BUT this can be within the Dyno error and while at the same temperature/humidity, engine temp can affect it as well. I would check the cats but I don't have them on my cars.
Old Dec 15, 2019 | 11:06 AM
AaronLin's Avatar
Both Redline and Keropur are 2 of the best fuel additive for modern engine. And I usually add one bottle of Keropur every 3000 miles (4800 km)
Old Dec 15, 2019 | 02:07 PM
George05's Avatar
Injector cleaner every 3rd tankfull
Old Dec 15, 2019 | 04:05 PM
RacerX's Avatar
Banned
Maybe it's all wrong, but I can't help myself.
6 oz of Boostane for drag racing for 100 octane to prevent detonation with my 650 HP tune/pulley, it also increases day to day pops and crackles.
MOS2 goes in to thicken the oil and reduce friction. I change the oil <2K miles and change the filter every 10K miles.
BG44K every 15K miles for GDI.
Old Dec 16, 2019 | 07:45 AM
SinF's Avatar
If thicker oil was called for, why not just use a different engine oil viscosity? Make sure you are not causing harm with oil additives that reduce flow and may form deposits.
Old Dec 16, 2019 | 04:58 PM
Unhingd's Avatar
I’d be more worried about the oil being too thick for the variable valve train to operate properly.
Old Dec 16, 2019 | 08:52 PM
Mahjik's Avatar
I use BG 44K once every year. I've never been a fan of oil additives.
Old Dec 16, 2019 | 09:16 PM
RacerX's Avatar
Banned
It is a never ending debate, but I prefer wear protection over gas mileage. Castrol says their 0W-20 weight is to extend gas mileage. They recommend 10W-60 weight in high stress supercars and say it is suitable for everyday driving. The F-Type runs notoriously hot.
I use Royal Purple 5W-30 cuz I live in a hot climate I've seen RP transform previous cars of mine, so what do I know? 🙄 I have considered going with Edge Supercar due to the engine heat.
https://www.castrol.com/en_us/united...rformance.html
https://www.castrol.com/en_us/united...-supercar.html
Old Dec 16, 2019 | 10:08 PM
Luc Lapierre's Avatar
Surely this is superfluous?? I thought once per year was adequate.
Old Dec 17, 2019 | 01:58 AM
RacerX's Avatar
Banned
But Castrol loses me altogether when they write
  • Helps improve fuel economy (0W grades)
How can a reputable engine oil company's main website be so bad they don't even understand what the basic numbers mean?
Old Dec 17, 2019 | 07:59 AM
Carbuff2's Avatar
I think that the conundrum with our Jaguar engines are the demands of the variable valve system and performance. Hence, the Jag spec demands a 'thin' oil that 'protects' well.
I understand the confusion. On Honda engines the factory recommends 0W-20 for 'common' models but 5W-30 for 'performance' variants that they know will be thrashed. I bet they have RacerX's picture on the wall for inspiration.
Old Dec 17, 2019 | 08:07 AM
SinF's Avatar
Maybe I don't understand modern engine machining, but I believe oil viscosity is directly related to tolerances. If you put 15w50 oil into F-type I am all but certain you will end up with a dead engine - it won't provide sufficient lubrication for designed tolerances. Now, I don't know the consequences of using 5w30 oil in applications calling for 0w20 - likely nothing, but it still a risk (if only of the risk of unknown).
When you compare 'common' to 'performance' Honda engines, they are not the same engine manufactured to the same spec.
Old Dec 17, 2019 | 08:42 AM
Carbuff2's Avatar
SIGH another OIL discussion.
Some Honda engines (Civic SI compared to 'normal') are the same, but with different oil specs. (I was called out on this once.)
Tolerances DO play a part...but again using Honda as an example, they spec 0W-20 in the USA but up to 10W-40 in warmer markets. Same VTEC hardware.
Another example: The Toyota engines used in S2 Lotus Elises spec'd 5W-20 oil in Celicas, but Lotus recommended 5W-40 in their cars (and they never modified ANY of the internals, just ECU programming).
I don't think that any of us laymen could measure a difference in engine performance or wear over the life of our engines, especially with one grade difference. Look at some of the Blackstone results on BobIsTheOilGuy...some oils 'thin down' over time (especially when used in GDI engines), others don't. My belief is that the Titanium spec from Jaguar is an attempt to mitigate these issues.
Hey, I'm an enthusiast, and I change our oil myself every year (5000 miles last year), no dealer is going to use Bulk Oil in OUR engine.
Tcasmarcus
Jan 13, 2018 03:38 PM
andyXJR
Feb 18, 2017 04:34 PM
matts89xj
XJ40 ( XJ81 )
17
Sep 16, 2013 09:25 PM
Bigvettefreak
Oct 23, 2011 11:55 PM
v8stype
16
Mar 6, 2011 07:50 PM
