Door Sill Plate Removal
Old May 4, 2019 | 10:58 AM
fujicoupe's Avatar
Banned
Default Door Sill Plate Removal
Does anyone know how to remove the brushed stainless steel door sill plates? I'd like to swap right for left and vice versa. Why you ask? Well, because the dealer scratched the driver side sill while the car was in for its first year service (among other things) and I don't want to look at the scratch every time I get in
The entire saga of the week long first service ordeal will be posted later after I gather my thoughts and have time to compose them (and myself.)
Old May 4, 2019 | 11:14 AM
FeralSVR's Avatar
Have you tried to submit a warranty claim?
Old May 4, 2019 | 11:33 AM
fujicoupe's Avatar
Banned
It wasn't a manufacturing defect; it was damage done by the dealer when in for service. How would that be a warranty issue?
Old May 4, 2019 | 12:13 PM
KVO's Avatar
KVO
Dealer scratched car, dealer needs to fix for free, it is as simple as that!
Old May 4, 2019 | 01:04 PM
FeralSVR's Avatar
Copy that! Dealer damage is covered by warranty...
Old May 4, 2019 | 01:52 PM
Nati's Avatar
The chances of the piece being removed without destroying it are very low. Requires a heat gun and lots of patience. They essentially need to be replaced with new parts when you take them out.
Old May 4, 2019 | 01:53 PM
Nati's Avatar
Dealer damage is not covered by warranty. Dealer damage is eaten by the dealer. You think Jag is going to reimburse them for baffoonery?
Old May 4, 2019 | 02:12 PM
sov211's Avatar
this is correct, and it is also correct that the sill plate cannot be removed without damage. I replaced mine because of scratching ( which is clearly not a warranty issue - why anyone would think it would be is beyond my comprehension)...as stated it requires heat, an instrument to separate the metal from the adhesive backing and ultimately you end up just pulling it off - -and this makes it unusable. Do not try to remove a sill plate without have a new one at hand.
Old May 4, 2019 | 02:21 PM
Does anyone know how to remove the brushed stainless steel door sill plates? .....
I can tell you how to do it BUT the LH and RH tread plates are not interchangeable!
Jaguar have used the same method of attaching tread plates for many years. They are bonded with a single length of double sided tape located as shown in the second diagram.
They are removed by carefully warming with a heat gun and gently prising free working from the end with a long plastic blade. They are easily damaged and the technique is to apply only sufficient heat to soften the bond and only prise after the adhesive has softened. They release gradually - it takes time and care.
Clean the tape residue and use a new length of 3M or equivalent to re-attach.
Old May 4, 2019 | 02:48 PM
fujicoupe's Avatar
Banned
Thanks for the input everyone. I was hoping for an easy swap to avoid having to repaint a new part and pestering the dealer for another damaged--piece even though they did it. The small scratch/dent wouldn't bother me if it weren't on the driver's side, but I see it every time I open the door.
I'll take a poll on whether I'm being too picky by trying to attach a pic.
Old May 4, 2019 | 03:48 PM
Unhingd's Avatar
If it bothers YOU, ask the dealer to replace, but they may claim you did it. I suspect after a couple years and 10's of thousands of miles of use, that'll be the least of the door sill blemishes.
Old May 4, 2019 | 05:14 PM
DJS's Avatar
DJS
Sand or buff it? Or fill it?
Amazon Amazon
Old May 4, 2019 | 05:27 PM
Jim F's Avatar
I ordered illuminated tread plates with the car which were dealer-installed. I asked them to save the original plates, but they were pretty much destroyed in the removal.
To protect the illuminated tread plates I installed XPEL Clear Universal Door Sill Guard:
Amazon Amazon
Old May 5, 2019 | 11:27 AM
Tel's Avatar
Tel
I installed some offcuts form my PPF wrap; Expel ultimate on the plastic part where you swing your shoes in throught the door aperture - total overkill, but not a single scuff mark.
Old May 5, 2019 | 01:51 PM
Swoody's Avatar
That little tiny mark to the right of the R??? If that’s it.... boy, mine would put you over the edge!! LOL
Old May 5, 2019 | 02:56 PM
fujicoupe's Avatar
Banned
Yep, that's me, Mr. **** OC. Point of fact is after one year there was not a mark on it until my dealership worked its magic. That's not all the havoc they wreaked, but I've not composed that story just yet.
Old May 5, 2019 | 06:48 PM
stmcknig's Avatar
Yes that tape sure does grip. I didn't like the scratches on the original sill plates when I got my new-to-me ride. I also thought the brushed finish was a little coarse and cheap looking so tracked down a pair of the Union Jack version which are much nicer. I didn't worry too much about keeping the originals for replacement but even with a hot air gun and some trim removal tools, carnage was inevitable. A little blood sacrifice was also required but I think the end result was worth it.
Old May 6, 2019 | 09:52 AM
Jaggyx's Avatar
Post #110. Looks like he was able to remove them.
https://www.jaguarforums.com/forum/f...-179586/page3/
Old May 9, 2019 | 06:56 AM
SS4PK's Avatar
I like those, are they OEM?
Old May 10, 2019 | 01:55 PM
stmcknig's Avatar
Yes they are - T2R5985
I actually ordered them from a dealer in the UK because it was way cheaper..
mannymux
Aug 20, 2021 04:32 PM
Sinister 1
Oct 27, 2014 01:26 PM
turbo68
Jun 13, 2014 12:30 AM
stremsjg
Detailing / Car care
Mar 18, 2013 05:56 AM
WHealy
May 17, 2012 07:01 AM
