Engine / transmission light on
Old Oct 21, 2014 | 06:03 PM
ek993's Avatar
Default Engine / transmission light on
Car is. 2014 V8S with 4k miles, I have owned it since new with 0 miles - check engine light came on today. Checked the oil level, the computer says ok.
I will make an appointment with Jaguar, but has anyone had this and what did it turn out to be?
Old Oct 21, 2014 | 06:16 PM
DJS's Avatar
DJS
Mine has come on many times - 2 (or 3, I've lost count) O2 sensors and a vapor recovery valve. The check engine light has come on 3 times since I last took it in, but has gone out on its own. Haven't gotten around to going back in.
Old Oct 21, 2014 | 10:55 PM
Foosh's Avatar
4K miles, and check engine light never on. Never back to the dealer since delivery.
EDIT/PS: Check your gas cap and make sure it's threaded properly and sealed with at least 3 clicks. I know this may sound silly, but that is one of the most common causes of a check engine light.
Old Oct 22, 2014 | 08:28 AM
DJS's Avatar
DJS
Yup. I believe the Check Engine light is generally related to emissions, and not anything serious. I wasn't in a hurry to take my car in, and most times, the light has gone off on its own. Still worth having the dealer see what the deal is.
Old Oct 22, 2014 | 01:42 PM
ek993's Avatar
Thanks guys, checked the gas cap that was on nice and tight so no issue there.
Will make an appointment for the next couple of weeks but sounds like its not really urgent.
Old Oct 22, 2014 | 02:54 PM
Foosh's Avatar
Even if it were something simple like a loose gas cap, it often takes the system awhile to reset. It would be a good idea to drive it for a week or so to give it a chance to reset, and if it does, it may not reoccur.
Old Oct 22, 2014 | 04:54 PM
axr6's Avatar
You can always get an inexpensive OBD II code reader which also resets the CEL condition. If you find an error code you can always Google its description on the web. Here is one that works with Android phones but, there are many others on the market.
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
Old Oct 23, 2014 | 08:53 PM
ek993's Avatar
As you predicted the light went out by itself tonight. I did remove and replace the gas cap so who knows, could have been that.
Old Oct 24, 2014 | 07:34 AM
Foosh's Avatar
Good to hear. It's always nice when something is simple. If it does light up again, then you can get it checked at the dealer, but it quite likely won't.
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
Woznaldo
Jan 31, 2016 03:22 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
NinoGrimace
Aug 26, 2015 05:15 AM
