Hello there
My FType AC seems to have lost the plot.
the Fan speed is all over the place when on auto or not.
the temp is also all over the place.
When I start the car the AC comes on and cools if I have it set to 21 for example, after a few miles it decides you must be cold and boasts hot air even when it’s roasting outside.
sometimes the reverse happens I can be in the car and the fan slows down on a cold day and it starts randomly blowing cold air at various fan speeds.
I checked and this car doesn’t appear to have a variable resistor to swap out or I cannot find it.
does anyone have any idea what the problem could be or how to fix it, it used to work brilliantly when on 21 for example now it doesn’t seem to know if it’s hot or cold in the car
Some sort of temperature sensor? It appears your A/C works OK - it can blow cold air, just not when you want it to. I would focus on whatever sends temperature readings back to the A/C unit telling it when to blow cold air.
Jaguars used a small aspirator fan located near the steering column behind a small grille to draw cabin temperature air across a sensor. These were fitted on all Jags up to and including the models immediately before the F-Type (including the X150) but I cannot picture where such a fan is located on the X152 but it will be located either on the steering column shroud or nearby on the dash panel.
In any case, the part number for the F-Type cabin temperature sensor is T2R3569.
Hello there, thank you for your advice, It does indeed sound like its the sensor which Is much cheaper than the entire control unit.
I have found the small grill round opening at about the 8 o clock position when looking at the Stearing wheel.
What is the way to remove the trim under the wheel correctly to get to this part and remove it.
I also wonder if its possible to test this part with a multi meter.
I will today remove the sensor if I can take the trim off and it might fix things.
Scrap that its at the 9PM location on the dash, I started to remove the panel below the Stearing wheel and noticed that its behind the middle bit below the Instrument panel.
Now to search for a video on that
Hello There
Things I learnt today that might help someone else
You dont get to it from behind the infotainment system even if it looks like you do
To get to the cabin air sensor you have to take the bit below the instrument cluster off along with the footwell panel
these use T20 and T30 screws for the footwell panel and the part below the instrument panel pops off with a trim removal tool and a little wiggling.
the part number for the FTYPE 2014 is EX53-19C734-AA
Mine was clogged up with fluff etc
I broke it when taking it out so if it want the fault i need to replace it anyway but I plugged it back in.
£55 replacement part from Jag
After a good clean the fan spins freely and a good drive will tell me if this was the problem.
Hello There
Let us know how this turns out! I have some weird AV issues from time to time as well.
Hello there
so after a new days of driving with the sensor hanging out as I have to order a new one and collect tomorrow I can confirm the AC is working normally.
Its set to 21 and cooling and heating as and when needed.
I dont think it was the thermostat originally it was broken inside the dash or had become disconnected from the part that gets air from the dash along with the fan being clogged up after ten year.
£55 fix rather than a garage investigating and perhaps replacing another part first.
Hello there
Thanks for the update!! I'll take a look at this on my car and see if it's clogged as well!
Hello there
Since I have owned this car the AC has been a bit wonky and never seemed to know what fans speed or temp to blow. Got a new compressor installed, had it tested and recharged, all to no avail. It would also sometimes not work at idle, blowing warm air until you left the stoplight and got underway. There were no faults and nothing anyone could detect, it just didn't work right.
I just went the car armed with a qtip dipped in isopropyl alcohol and a a small vacuum cleaner and fixed the issue in about 6 minutes. I was able to remove the trim piece by grasping and pulling, then two T15 screws remove the housing and sensor. I vacuumed the sensor, stuck the dry end in the sensor fan blades and pulled out clumps of lint, then followed up with the damp qtip. Got it back together and now the AC works as intended.
Thanks again for the original post - I'm not sure I would have gotten to this solution on my own, and the dealership certainly never would have.
If your AC is acting up or suddenly blowing cold when you have selected heat this is worth a try. It's easy to pop off the trim above the steering wheel and access the unit, which looks like this:
I removed the 2 screws but could not completely remove the unit, but I was able to twist it to see down the "horn" with a bright headlight. Beware there is a spinning fan below the 2 metal sensor wires if the car is awake, so its best to wait for it to go into sleep mode first before inserting anything into the "horn". There was a surprisingly large piece of lint + dust wedged between the fan and the sensor wires that I carefully removed with some fine tweezers.
Is the "horn" there below the tach and above the stalk? I have trim removal tools, looking for guidance as to where to insert tool to pop off trim piece. No issues as yet, but want to file this in case.
Yes Valerie that's the horn. The trim piece is resting on the dash after I removed it. The oval vent on the trim piece is where the horn intake is located just behind it.
Pops out easily just by prying a little, grabbing the edges and pulling out. Snaps back in just as easily. Would be impossible to break if going slow and gentle, so no fear!
@Carbuff2 Give it a whirl and see what's in your friend's horn. Foreign material like lint and hair may transiently affect the current across the 2 sensor wires just above the fan and mess up the temperature reading.
Great photo and I appreciate the work note help. Deadly fear of breaking parts. I pried that little triangular plastic piece off the door side/edge toaccess screw and remove the door card and broke the plastic piece. $50 for that little *&^$% piece of plastic!!!!!!!!!!!!!
