F-Type R75 AWD Coupe Ownership Thread
Old Feb 24, 2026 | 06:37 AM
  #101
bfrank1972's Avatar
Originally Posted by wachuko
Thank you. So much for using those with this car, sigh…
If you have them already why not try to fit them up and look at the clearances?
Old Feb 24, 2026 | 07:30 AM
  #102
wachuko's Avatar
Thumbs up
Originally Posted by JagCode3
I don't know if FL is a mandatory front license plate state but a Sto N Sho plate mount is the way to go. You can keep the plate in the trunk in case you are pulled over and just say you took it off for the carwash and forgot to put it back on!
I have this cover and it fits perfectly and looks good too. (BMW 3 series is the right fit for the F-Type).
Front license plate not required in FL.
Thank you for the link to the cover. I will take a look.
Old Feb 24, 2026 | 08:53 AM
  #103
wachuko's Avatar
Ordered a couple of oil filters and an oil filter cap wrench. Motivx MX2325
Old Feb 24, 2026 | 08:57 AM
  #104
wachuko's Avatar
Thumbs up
Guess that I could. I will measure off-set on that front wheel. I do not want to hit the caliper with the 19" wheel if the issue is related to not enough depth to clear the face of the caliper.
Old Feb 24, 2026 | 11:49 AM
  #105
wachuko's Avatar
Post
I was reminded that I also want to add this: Overheating Early Warning that you (@JagCode3) did. The OBDII display you initially used is now replaced for another version. Shadow OBDII Display
I know you replaced the display with an android display/phone... not sure I want to go there right away. I like the small display solution for now. I have a small android tablet with the Torque app (that I used when I had my Chevy ZR2), so I could go that route in the future.
Also reminds me that I need to find an elegant phone mount solution as well...
Old Feb 24, 2026 | 01:34 PM
  #106
BritCars's Avatar
Sorry about that! You could always test whether a spacer would move the wheel out and allow it to clear - although front spacers might make it poke out too far. You may be selling those and picking up a replacement set
I ordered a set of jag replica wheels (on eBay) as the winter wheels for my F Pace. They cost about $400 each (new), made to all the oem size, offset etc. I've used them two seasons in the harsh winter and they have been great. I would be hesitant to buy used wheels in case they have been bent or damaged. But replica new ones seem like a good deal.
Old Feb 24, 2026 | 07:19 PM
  #107
DMeister's Avatar
That’s the one I bought. Quality tool.
Old Feb 24, 2026 | 07:23 PM
  #108
DMeister's Avatar
Do you know what is different with the new version of this Shadow OBD2 device? Louder alarm, or anything like that? Read comments that it might not be loud enough on the original device or something.
Did you determine anywhere the exact data points this thing will for sure support out of the box on the f-type specifically?
I’m considering this thing as well.
Old Feb 24, 2026 | 07:42 PM
  #109
DMeister's Avatar
ALSO, I noticed this other model on Shadow’s website. Similar, but it seems you can display more data points at the same same time…
https://shadowmeter.com/products/fd-...47103184076967
Old Feb 24, 2026 | 07:54 PM
  #110
wachuko's Avatar
I do not… still researching. I was going to ask, in the thread started on that topic, to get some feedback from those folks that still have it.
Old Feb 25, 2026 | 03:51 PM
  #111
JagCode3's Avatar
I would use an Android phone / tablet and Torque Pro. It's not complicated at all.
The Shadow was OK and looked good but the audible alarm could not be heard over loud music.
I wanted something with a loud audible and visual alarm when the engine started overheating. I gave mine to another forum member.
Old Feb 25, 2026 | 05:48 PM
  #112
DMeister's Avatar
I have Android Auto in my F-type. Would that app display properly on my entertainment screen using that? Do you do that?
Just curious.
Old Feb 25, 2026 | 06:07 PM
  #113
wachuko's Avatar
I still have mine… photo when it was in my truck
But such a large setup. Maybe I should just get a smaller display/tablet/phone . I just liked the idea of a small screen on the steering wheel. Looked almost factory.
I see there is a thread with PIDs available from a forum member:
https://www.jaguarforums.com/forum/g...p-more-213503/
Old Feb 26, 2026 | 03:25 PM
  #114
JagCode3's Avatar
No, Torque Pro is not Android Auto compatible last time I checked. It would only appear on the phone or tablet screen. But the audible alarm is the key - it will disrupt music and a phone call to let you know the temperature has reached a critical threshold set by you. I have a visual flashing alert at 220 F and a loud alarm at 230 F.
I do not want to lose my engine to this Achilles Heel that can happen even with the new aluminum pipes - they leak too, usually right after installation because of the O rings not seated right.
@wachuko does your new F-Type have the aluminum coolant pipes?
Those PIDs from 7 years ago never worked for me and others who tried them...
Old Feb 26, 2026 | 05:52 PM
  #115
DMeister's Avatar
Someone in this threads says Android Auto worked for him to get it up on the screen…Post 45…Shows a pic of it…
https://www.jaguarforums.com/forum/g...-213503/page3/
Old Feb 26, 2026 | 06:06 PM
  #116
DMeister's Avatar
Okay, so I guess Android Auto is possible, but it’s a bit hacky. Ya gotta side load something dodgy to get it working or something…
Found this app OBDFusion which supposedly natively support Android Auto. It also runs on iOS, so I would imagine it supports CarPlay as well.
Question is, can it display as many datapoints as Torque Pro…Not sure…
https://www.obdsoftware.net/software/obdfusion
Old Feb 26, 2026 | 06:46 PM
  #117
DMeister's Avatar
I’m starting to lean towards this OBDFusion I linked above. It just feels more flexible/polished. It fully works with both iOS and Android and Android Auto and Apple CarPlay.
Also, there’s a clean easy way to access the custom pids for various vehicles, including JLR it seems. So you just pay 10 to 15 bucks in the app for some upgrade pack for your vehicle of choice and it will just automatically setup and make available all the custom stuff for ya.
Sounds like a winner to me. Kinda leaning in this direction now.
Rather detailed video on OBDFusion:
Old Feb 27, 2026 | 10:00 AM
  #118
jdsengineer's Avatar
Thank you. Video worked for me. No issues with the link. Reposting just in case:
https://youtu.be/OPlg4BSMDIo?si=UIXUreLOgCvE86m2
I pulled the plug the other day and yes, the stop start function was disabled. However, the yellow light on the console button still stays on all the time.
For me the yellow light on is so annoying I might put the plug back in and just hit the button on startup like I've been doing all along.
I guess my OCD is getting the better of me.
Old Feb 27, 2026 | 11:21 AM
  #119
wachuko's Avatar
I can live with the light on the center console. Small price to pay to avoid forgetting hitting that button and deactivating the Auto Stop/Start.
Old Feb 27, 2026 | 12:03 PM
  #120
DJS's Avatar
DJS
Interesting. In my two-battery car (now down to 1 battery), the light on the ECO button in the center console comes on when I start the car, but turns itself off after 10-20 seconds.
